Space
Roesso
Space
Post by Roesso »
How far apart does my upper and lower link need to be. I'm building a crawler and Im very new to the crawler world. I cut my links last night they are 8 1/2 inches .I'm wanting to build my own chassis .any help would be greatly appreciated
87lc2
Re: Space
Post by 87lc2 »
It's hard to give an exact answer on this. It depends on where you are mounting the links. With a Clod you dont have to worry about pinion angle, but you want to make sure you have the caster right for the steering. I would set it up to have the axle positioned at 0 caster or slight negative caster, that will give the best steering performance.
