TXT-2 on 3S - good idea?
Peter_B
Post by Peter_B » Sat Aug 25, 2018 7:07 am
My TXT-2 is setup with a single Speed Passion MMM 13.5 motor (3300kv I believe) and a Hobbywing 10BL120 ESC. Gearing is stock although it does have TXT-1 wheels and Clod tyres fitted.
The other day I ordered a couple of 2S lipos, and while I was at it, I added a 3S to the order. Specifically because I thought the TXT might benefit from some extra juice.
Other than a quick test using NiMH I haven't really run the truck yet.
Is chucking the 3S in it a good idea?
Re: TXT-2 on 3S - good idea?
Post by shadowfocus603 » Sat Aug 25, 2018 9:45 pm
Your electronics are up to the task. Just be sure to monitor motor temps and be prepared to run a smaller pinion or a larger spur if the motor gets too hot. And if the txt has any inherent weaknesses extra speed and power will find them. This coming from a contender for the title Captain Kaboom lol.
