ground pounder diff gears
ratpower396
Post by ratpower396 » Tue Jul 31, 2018 1:18 am
Are there heavy duty diff gears available for the ground pounder? Or could axial ar60 axle gears be a possible replacement?
NorthernNightmare
Re: ground pounder diff gears
Post by NorthernNightmare » Wed Aug 01, 2018 4:16 am
The gp diffs are the same as the exceed mad-cliff crawlers, as far as the R/P go.
id check if any axial diffs fit the mad-cliff as they are the same as your GP but more comen in the crawler side of things
