My recently acquired TXT-2
Peter_B
Post by Peter_B » Tue May 15, 2018 9:04 am
I recently got my hands on this
It appeared on eBay a few weeks ago, with a lot of alloy upgrades, for a price that was more than I could entertain.
Turns out it ended up being bought by a chap local to me, who I bought my Clodbuster from last year. He decided it wasn't for him so tried to sell it on as it was. He didn't have any luck with that so started stripping off some of the upgrades to sell and replacing them with stock parts.
Then he put it up for sale again, this time at a price closer to my valuation. So a deal was done 8)
As it stands now it's a pretty much stock TXT-2. It's got the alloy bumpers, Traxxas springs, and RC4WD aluminium beadlock wheels.
There isn't a sticker on that body - it's all paint.
Pretty pleased with it, especially as I got it for less than the wheels and tyres would cost on their own :)
The plan is to get it up and running - it needs a full set of electrics, I'm thinking of going with a single brushless motor. Swap out the shocks and maybe change the beadlocks for a set of TXT-1 wheels. Those beadlocks are nice but they are very heavy.
Looking at it, it looks to me as if either the bumpers are on the wrong ends, or the body (and wheels) are on back to front. So I'll have to investigate, figure out which end is the front and remount everything accordingly.
Re: My recently acquired TXT-2
Post by GRAVETXT-1 » Tue May 15, 2018 1:38 pm
You could sell the body separately and make back the money you spent on buying the truck the original owner would have spent a fortune having the body custom painted and then shipped back to the UK! 8)
NorthernNightmare
Post by NorthernNightmare » Wed May 16, 2018 1:46 pm
Nice looking rig, sounds like you did a great deal on it too.
If you wana ditch the alloy rims i could understand. As i got a set of the alloy and a set delrin versions, both are a bit on the heavy side but the alloy ones are just out of control. Even when you do got the power to spin them, they feel like gyros that wont stop till there tear up something
Where are you located, i have a lighter set of delrin units, id trade for alloy if that helps.
Post by Sixtys Guy » Wed May 16, 2018 9:57 pm
Nice! The TXT-2 is one of my favourite trucks.
Peter_B
Post by Peter_B » Mon May 21, 2018 6:16 pm
I'm in the UK but think I'll hang on to the alloys for now.
I do have a question though, seeing as you have experience of the wheels.
I've just gotten round to taking the wheels off and was surprised to find 3 bushes as spacers between each wheel nut and the wheel.
I'm assuming they are there because the wheels are designed for a Clod and the TXT has longer axles.
But is there a better, more proper, solution than a bunch of old bushes?
matt1ptkn
Post by matt1ptkn » Tue May 22, 2018 11:34 am
Now those are some body posts! :shock: I am scratching my head over your front/back dilemma. It's never occurred to me, that not being the builder of a truck such as this, that it would be nearly symmetric front to back. I suppose it shouldn't really matter, right? But that is an interesting situation.
Great looking truck, BTW.
-Matt
My Trucks
NorthernNightmare
Post by NorthernNightmare » Wed May 23, 2018 12:53 am
Yup thats normal on both the clod and txt-1 with the rc4wd wheels.
The only solution Im aware of is if you switch to thunder tech cvd axle shafts that are 8mm and uses a different mounting style but dont need the extended bushings.
I currently got the wheels on other builds that are more of a show vehicals as they just tear up shafts left and right all day...
Post by Sixtys Guy » Wed May 23, 2018 3:13 am
I know when I went to install CPE wideners on my TXT-2 they didn't work as the axles were too long, as you have said. I switched to Clod axles and all good. I assume this would work the same for your wheels.
Peter_B
Post by Peter_B » Thu May 24, 2018 12:53 pm
As an update, I've figure out which end is the front - battery is at the back right?
I've mounted up some electrics - a Hobbywing 10BL120 ESC driving a single Speed Passion 13.5 MMM brushless motor, a Trackstar 21.5kg servo (only one for now as I need another E2 part for the rear servo).
I've also fitted a set of the TXT-2 hop up aluminium shocks. The guy I got the truck from had removed them intending to sell them separately and I was able to make a deal for them and the aluminium body mounts that had been fitted originally too.
When I mounted the servo I found that, with the kit spec servo saver, the drag link couldn't be mounted because the servo saver was in the way (the Traxxas servo that was fitted when I got it had a non kit spec servo arm fitted). AFter puzzling over it for a while I realised that the steering knuckles were mounted upside down and on the wrong sides, putting the drag link too low.
Once I realised that it was a simple job to swap the knuckles over, although I also found that the knuckles were missing the washer that sit top and bottom to prevent the king pin screws from binding - got some egenric 4mm washers on the way hopefully they'll do the job.
I couldn't mount the rear servo due to the lack of the E2 ervo saver part. But, given what I'd found at the front, I decided to check and prepare so I could just drop a servo in. I found the exact same problems at the rear - upside down steering knuckles and missing washers. Once I'd sorted those out it was ready to be driven.
My first impressions were that it doesn't turn very well at all with only the front wheels steering. Partly I think that's the weight of it, especially those wheels. I also noticed the wheel alignment was off - toe-in at the front, toe-out at the rear - which won't have helped.
Second thing I noticed was that it was quite slow. Although I think this can be accounted for by the fact I didn't have a fully charged battery so grabbed the part charged NiMH pack from my boys Lunchbox. I also hadn't done anything to the ESC other than set the throttle range. Undoubtedly the weight plays a part here too.
Next step is to get some washers in place on the steering knuckles, get the second servo mounted and sort out the wheel alignment as best I can. Then see how it drives with a fully charged battery.
After that I might try some TXT-1 wheels and see how much difference lighter wheels make.
Post by Sixtys Guy » Fri May 25, 2018 4:10 am
Yep, battery to the rear. It's a slow truck. You can try 3s with the stock motors for some more go. I'm running a 3900kv brushless motor. I was running 4400kv, but with the weight of the truck I was breaking stuff.
Peter_B
Post by Peter_B » Fri May 25, 2018 10:09 am
Thanks for confirming battery to the rear.
I don't have the stock motors, it didn't come to me with any motors, so it is running a 13.5T Speed Passion brushless which I think is about 3300kv.
I'll sort out the other little niggles and then try a fully charged NiMH in it to see what it goes like - I don't have any LiPos for my Tamiya cars currently. I've got a bit of scope to up the motor kv slightly so that's always an option in the future.
Post by Sixtys Guy » Fri May 25, 2018 10:38 am
yeh sorry I did read that you have a 3300kv motor. My 3900kv motor is 4 pole and I find it quite good. Can't remember what pinion I am running but it has great power down low. Maybe lacks a little top end, but I don't think it is slow for what it is.
Peter_B
Post by Peter_B » Mon Nov 19, 2018 11:49 am
Coming back to update after a few months.
I got all the bits and pieces I need to finish off mounting the steering knuckles correctly and mounted a second servo for 4WS. I also swapped the aluminium wheels for a set of TXT-1 wheels (managed to sell the aluminium ones on for a decent amount). I invested in some Core RC stick sized 2S LiPos, for this and my other cars. I've also got an Overlander 3S LiPo specifically for the TXT but I haven't run it yet.
I eventually got a chance to give the truck a proper run when I took my boys and their cars to a local country park. I was running the TXT with the Hobbywing 10BL120 ESC, the Speed Passion 13.5 MMM motor with a kit standard 19t pinion and running the 2S LiPos.
I was quite impressed with the performance, it would wheelie fairly easily on take off and had a decent enough turn of speed.
However I am slightly concerned that it is a big old heavy truck for that one buggy sized motor to shift around. So, I've been on the lookout for a possible alternative, without wanting to go for a 1:8 scale setup that would make mincemeat of the transmission. Anyway, I came across a SkyRC Ares S-Pro2 SCT motor for pretty cheap. https://www.skyrc.eu/skyrc-ares-s-pro2- ... p-199.html
It's a 6.5T motor rated at 3400kv but is a 550 sized motor vs the 13.5T 3300kv 540 sized motor that I have installed currently. I'm hoping that it will be better suited to the size of the truck. It has a 5mm shaft though so I'm currently waiting for a set of 5mm bore pinions to arrive before I can mount it.
Has anybody used one of those motors, or similar spec, and can recommend where to start with pinion size? I was thinking I'd start with a 19t and go from there.
Picture from the first proper run Image
Peter_B
Post by Peter_B » Thu Apr 11, 2019 7:18 pm
Coming back to update...
I finally got around to swapping the SkyRC Ares SCT motor in. Fitting the motor wasn't a straightforward job. It has a longer shaft than the 3650 sized motors and the shaft would bind on the back of the gearbox casing.
I got around that by ordering another motor mount plate and simply doubling up. That gave me the couple of mm needed for clearance.
First run was today. I went with the standard TXT-2 pinion size of 19t. There was bags of torque - too much throttle from standing would sit the truck on the rear bumper. After a good thrash about the motor was ice cold so I can probably up the pinion size without any worries. Hopefully doing so will also calm the take off as well.
Now I just have the joy of pulling the transmission out again so I can swap the pinion!
Post by SFC K » Fri Apr 12, 2019 4:45 am
Nice looking Truck and love the dual shocks per corner!
Fun stuff is the wrenching so enjoy! I know I do! Also, if you have a dual rate functions on your remote, you could dial back the throttle so it doesn't have so much punch off the start if you find the next pinion change is still to much.
