more holes??
BLAZE86DUBZ
more holes??
Post by BLAZE86DUBZ »
im getting ready to glue my tires to my rims but before i do i was wondering if i should drill more holes in the rims im running the proline destroyers tired with the brawler rims they seem awfull firm
Re: more holes??
Are you gluing these to the Brawler rims or stock Clod wheels?
BLAZE86DUBZ
Re: more holes??
the brawler rims
Re: more holes??
I drill extra holes (3, for a total of 4) in my stock wheels for use with stock tires, not sure if that's what you should do in your case though.
Re: more holes??
That is a tough call on the Brawlers. The way the wheels bolt together and vent I would hate to ruin them by drilling additional holes.
BLAZE86DUBZ
Re: more holes??
i'll run them the way they are see what happens
Re: more holes??
Post by 132NHAF »
One easy test is to just quickly squeeze them. If the air goes out with little resistance you're probably good to go
SWMS
Re: more holes??
Post by SWMS »
Just drill out the existing vent holes. Make sure to do this before bolting up the two halves of the Brawler wheels.
I recently did mine and drilled out the holes to 1/8".
BLAZE86DUBZ
Re: more holes??
i def have to drill the holes bigger there very bouncy off jumps
