gearbox grease
BLAZE86DUBZ
gearbox grease
Post by BLAZE86DUBZ »
do u guys run ur gearboxes dry or grease them if so whats a good grease to get ??
Re: gearbox grease
I use the stock Tamiya white grease and others have been using the Udder butter by CowRc. Dry is not recommended....
http://www.cowrc.com/store/#!/Udder-But ... p/43912822
jwscab
Re: gearbox grease
Post by jwscab »
i have used white lithium grease for years, but the trick is, just a little!!! put in on the gears in a couple places, and run them around to get completely coated. that's all you need unless you are using bushings, then you can stuff some in the gears behind the bushings.
