Need wheel stud?
Arthur33
Need wheel stud?
Post by Arthur33 »
[img][img][/img][/img]Hi i just bought a clodzilla 2 , it has the wheel widners on it, i was driving it around out side, and the driver rear tire fell off, i seen that the nut to hold the rim on, and the little stud that screws into the axel i guess with the wheel nut was gone. Where can i get them from, i dont know what the part is called, to try to even look for the piece to order, i need your help. Thank you
Re: Need wheel stud?
Could you show us a pic or two of your truck as well as close ups of the widener? There are several styles of wideners out there for clods.
I think the clodzilla one's used a barrel nut in place of the stock wheel nut, but without seeing what you have, it's hard to say for sure.
Brett from CPE sells barrel nuts in different lengths. This might help you find what you are looking for. Pictures like Andy said would help us best.
http://crawfordperformanceengineering.c ... el&x=0&y=0
Arthur33
Post by Arthur33 »
[img]
Arthur33
Post by Arthur33 »
Hi im trying to post some pictures but can't figure it out, but the axel has the widner on it, then like a stud sticking through it , then a nut screws into to hold the rim on
Post by Sixtys Guy »
Sounds like TTR Wideners. Message Brad with a pic of what you are after and he should be able to sort you out.
http://www.thundertechracing.com/wide.htm
Arthur33
Post by Arthur33 »
My widners are shaped almost like a stop sign, and have the hex cut out on the back, and has i think 5 holes in it for the little nipples on the rim to stick in. I cant send pictures i tried but i guess im not doing it write
Not mine, but this shows a clodzilla with the optional ESP wide-ride widening kit.
Arthur33
Post by Arthur33 »
Hi, yes those are the clod widners i have on mine. My center stud fell out of the center of the widner along with the nut holding the rim and tire on . Where can i get the stud. I checked ebay but not sure what to write out to find it
Probably what your going to have to end up doing is finding the right length barrel nut to replace the stud.
Arthur33
Post by Arthur33 »
Where do i get one of them
I'm thinking here:
http://store.rc4wd.com/search.asp?keywo ... l+nut&www=
But I'm not sure what one is the right one.
Thunder VP
Post by Thunder VP »
I think the ESP sets used a 1/4" round aluminum standoff with 4mm threads. A setscrew is inserted for the threaded stud and standard 4mm nylock used to hold the wheel. Not sure length of stand off though.
Arthur33
Post by Arthur33 »
Thanks everybody for your time and help, gonna see if i can get a threaded rod . I know the wheel nut from a traxxas slash fits on the rod that i'm missing
