quick question
tober
quick question
Post by tober »
im looking to add traxxas ultra shocks to my clod, what screws are you using to mout the top of the shock? im planing on using the lower part of the original shocks to mount the bottom
Re: quick question
If you are using the Traxxas big bore shocks or ultra, make sure you get the plastic bushing that goes inside the mounting hole on the top of the shock. They should come with them if you are buying them new. I Use 3mm hardware at 20-25mm lengths. I also used washers on the outside of the shock hole before securing them with the 3mm lock nut. I could be wrong on the length though. I would need to take one of mine apart to give you the exact length I used.
