1 countdown over,,,
rex21
Re: 1 countdown over,,,
Post by rex21 »
Try using a soldering iron on the heads of the screws you want to remove. Should soften the loctite enough to remove them.
Skinner
Post by Skinner »
shadowfocus603 wrote:The loctite they use on those screws for the crossmembers is absolutely insane. I had to use a map torch with a tiny nozzle to heat JUST the crossmember then I had to slot the screws and use a flat screwdriver to remove them. I can appreciate the peace of mind of tight hardware but that was overkill. If you ever remove them replace them. The remaining loctite in the crossmember will foul up the threads and make threading in new hardware a pain. Conversely, you could clean the threads with a tap but I'd rather know they were new.
True last chassis i said hell with it and ground heads off and threw cross members out....made new ones and used new cap hardware minus lock tite.
~Pat~
Skinner
Post by Skinner »
rex21 wrote:Try using a soldering iron on the heads of the screws you want to remove. Should soften the loctite enough to remove them.
I know. Was too lazy go to barn for that route, by time stripped them cheap tork screws knew was done lol
~Pat~
Fatcatcustomz
Post by Fatcatcustomz »
Get this thing running already! :nana: :lol:
Skinner
Post by Skinner »
1Badclod85 wrote:Get this thing running already! :nana: :lol:
Lol idk been awaiting a email!!!! :nana:
~Pat~
Fatcatcustomz
Ohhhhhhhhh!!!! :mrgreen: :popcorn:
Skinner
Post by Skinner »
Well lil progress..... now I remember y I hate this servo set up......so awaiting the magic from Justin to be sent :twisted:
~Pat~
Fatcatcustomz
:lol: I'm either here to save the day or really f it up :rofl:
I'll send your parts out in the am boss
Skinner
Post by Skinner »
~Pat~
Skinner
Post by Skinner »
1Badclod85 wrote::lol: I'm either here to save the day or really f it up :rofl:
:rofl: don't make me slap a mag in :rofl:
~Pat~
What is so wrong with that set-up? :?
