shock choice
BLAZE86DUBZ
shock choice
Post by BLAZE86DUBZ » Sun Mar 20, 2016 1:40 pm
im in a process of doing a clod build i bought my axels from a fellow member here getting the CPE-TRMCFKIT: Complete Terminator Chassis Kit .now for shocks ordered the proline powerstroke rears there 102mm is that to long or short anyone run these ?? or should i get the fronts wich are 88mm??
Re: shock choice
Post by SFC K » Sun Mar 20, 2016 1:49 pm
I thought those chassis' use the shorter shocks. I'm sure someone that has run that chassis set-up will chime in.
BLAZE86DUBZ
Re: shock choice
Post by BLAZE86DUBZ » Sun Mar 20, 2016 1:56 pm
yea i hope so i dont wana order the wrong ones
&CLOD
Re: shock choice
Post by &CLOD » Mon Mar 21, 2016 1:57 am
I have a the newer Terminator chassis and run Proline Pro Spec fronts that are 88mm and it handles ok.In the past I ran 103 or 104mm Gmade shocks it seemed to handle a little better but they leaked also.It all really depends on what your going to do with it.There is enough mounting holes so you can make almost anything work.
BLAZE86DUBZ
Re: shock choice
Post by BLAZE86DUBZ » Mon Mar 21, 2016 10:31 pm
im just going to run the 102 mm proline what weight oil should i run in the shocks??
Fatcatcustomz
Re: shock choice
Post by Fatcatcustomz » Tue Mar 22, 2016 10:55 pm
32.5 should be fine
