Bearing upgrade process
~New members please stop in here and introduce yourselves.~
Dom1981
Post by Dom1981 » Wed Jan 16, 2019 4:08 pm
Hi Guys
Ordered new bearing kit for my clod.
Is there any recommended process for this and do I need a press to remove and install new ones..
Any pics appreciated
Dom
Steve C
Re: Bearing upgrade process
Post by Steve C » Wed Jan 16, 2019 5:37 pm
No press or special tools needed, just push the stock plastic bushings out and pop the new metal bearings right in. Did you get the full kit of 24? If so the 4 smaller ones are for the spur gears in the axles so you'll have to take the gearcase apart to install those. If you don't have the manual here is a link that will be helpful, this shows where everything is at https://www.tamiya.com/english/rc/rcman ... buster.pdf
Dom1981
Post by Dom1981 » Wed Jan 16, 2019 6:08 pm
Thanks very much
Yep got the full kit..
As I'm just doing shocks and locking rear steering might As Well do bearings.
I found the rear wheels don't spin as freely as front so thought possible bearings are not up to the job anymore.
Dom1981
Post by Dom1981 » Wed Jan 16, 2019 6:13 pm
I bought the clod which a previous owner had built.
Didn't realise it had so many.
Where they all located?
Dom1981
Post by Dom1981 » Wed Jan 16, 2019 7:23 pm
Looking at manual appears to be axles and gearbox?
Post by Halgar » Wed Jan 16, 2019 10:50 pm
Yes, they are in the axle tubes and gear box. The manual will locate them for you.
