Possible 6x6 Build (On a tight budget)
rknaub
Post by rknaub » Tue Aug 22, 2017 6:36 pm
Started tossing around the idea of building another 6x6. I've got a couple spare axles, and enough parts (minus gears/internals) to build a third. If I can scrounge enough parts up to make three full axles I may get started on this. My plan will be to 3D print most of the frame parts, except for the long (~36") frame rails, I will use some aluminum L stock for that, and print the braces and bottom pieces, make my own links, etc. I don't expect this to be a beauty, but should be functional and tough - all my 3D prints are taking a beating and have no issues yet. Spent a few minutes and drew something up in cad to get an idea of where I am going, surely there will be many issues to work out as it goes. Stay tuned...?
Re: Possible 6x6 Build
Post by Sixtys Guy » Wed Aug 23, 2017 2:28 am
:popcorn:
ratpower396
Post by ratpower396 » Thu Aug 24, 2017 1:33 pm
What material are you printing parts in?
rknaub
Post by rknaub » Thu Aug 24, 2017 2:36 pm
PLA because it's so readily available. I've used ABS in the past but I don't really see the need for it. Haven't had any issues with my PLA beadlocks, even on my brushless barbarian.
rknaub
Post by rknaub » Sun Aug 27, 2017 6:36 pm
Some early fitting and prototyping of parts. Not gonna use these shocks, but I can at least get some parts made using them as a mock-up.
ratpower396
Post by ratpower396 » Mon Aug 28, 2017 12:52 am
glad to hear about the pla. I printed some parts for a clodpounder build good to know it should hold up. Was considering petg if need something more heat resistant.
ratpower396
Post by ratpower396 » Mon Aug 28, 2017 12:53 am
just wondering what tires are those??
rknaub
Post by rknaub » Mon Aug 28, 2017 1:41 am
They're from a 1/8 scale New Bright Ford Raptor, with some printed beadlocks. A little bigger than clod tires, and a lot harder. Was going to use them for a mud truck, but since I had 8, I decided to go a different route.
rknaub
Post by rknaub » Tue Aug 29, 2017 1:35 am
That's good for tonight, I'm tired and I need some more 8-32 threaded rod anyway.
rknaub
Post by rknaub » Thu Aug 31, 2017 4:11 am
More progress tonight, third axle mounted. Very happy with how it's turning out. Lots to do still.
rknaub
Re: Possible 6x6 Build (On a tight budget)
Post by rknaub » Tue Sep 05, 2017 6:11 pm
Got some solar d772 servos and RC4wd 45T motors on the way. Has anyone ever used an EVX-2 esc with three motors? I have an evx2 laying around and decided to give it a try, wired two motors to one of the outputs and another to the other, and it works - albeit with no load on them. I was just wondering if I should put all three motors on one output or what? Do both outputs share the same wiring path? Does it matter? Regardless, the esc came in a trade and I have no other intended use for it, so if it goes kablooey I don't really care. My last 6x6 I used a Holmes esc and it worked fine with 3 35T motors, but I'm not gonna spend $100 when this seems to work.
ratpower396
Post by ratpower396 » Wed Sep 06, 2017 11:37 am
Only one way to find out....
rknaub
Post by rknaub » Fri Sep 08, 2017 12:53 am
So I took a voltmeter to the motor leads and the reds are tied together as well as the blacks, so I am gonna tie both outputs together and run them both to all three motors, which should be here tomorrow hopefully.
Trying to decide on a cab.. thinking this International Harvester might look cool, haven't decided on the rest of the bed - the cab is gonna take 1.5 spools of PLA to print, so about $23 - not bad really. With my Taz 6 I will be able to print it in one piece, roughly 270mm x 270mm.
International Harvester.JPG (51.16 KiB) Viewed 373 times
ratpower396
Post by ratpower396 » Fri Sep 08, 2017 7:10 pm
What program did you use to convert the cab picture
rknaub
Post by rknaub » Fri Sep 08, 2017 7:40 pm
Grabbed the stl from thingiverse, and used tinkercad to change the size, and make it fit on my frame rails.
