Extreme Kyosho Monster Tuber Build
NorthernNightmare
Post by NorthernNightmare » Sun Aug 20, 2017 1:36 am
I been planning this build in my head for a long time, it is going to be very unique with some twists 8) Hopefully I can get most the ideas I want included into the build, it starts with this chassi I welded up in 3/16" tubing.
The specs are mostly going off a savage XL body and wheel base. :)
Last edited by NorthernNightmare on Sun Nov 05, 2017 1:22 am, edited 1 time in total.
Re: Extreme Monster Tuber Build
Post by GRAVETXT-1 » Sun Aug 20, 2017 6:13 pm
Wow who needs MattZilla very neat job :thumbsup: will you be powder coating? What axles and transmission are you using? Looking forward to seeing this as a roller 8)
NorthernNightmare
Post by NorthernNightmare » Sun Aug 20, 2017 7:10 pm
Thanks man, The axles will be mad force 2.0 units, revo drive shafts connected to a upgraded revo/summit 2 speed transmission.
Just waiting on the trans and some small parts to mock up the truck as a roller.
NorthernNightmare
Post by NorthernNightmare » Wed Aug 30, 2017 8:04 pm
I ordered 7 complete mad force axle sets in total, x5 diffs and x3 sets of axle housings... 8)
But kinda screwed up in getting all fronts 8) For some reason I thought they where same front to rear #-o
not a huge deal planning to lock out the rear anyway with SS ends if they ever get back in stock :?:
Last edited by NorthernNightmare on Sun Nov 05, 2017 1:24 am, edited 1 time in total.
NorthernNightmare
Post by NorthernNightmare » Wed Aug 30, 2017 8:49 pm
The tires and wheels showed up today,
Also got in a set of swamp dawg 6.5'' and swamp kong too on chrome dimond rims. But the ones shown will go on the tuber build.
Post by Sixtys Guy » Wed Aug 30, 2017 9:22 pm
Tyres look good... are they the massive ones?
Post by SFC K » Wed Aug 30, 2017 10:52 pm
8) build! I have always wanted to tackle making a custom tube build of some sort. Looking forward to your twists! :wink:
NorthernNightmare
Post by NorthernNightmare » Thu Aug 31, 2017 10:20 pm
Thanks guys, I will updated this when a few more parts come in and I can make a roller out of it
And yup they are the big 8.5" units. The standared 6.5" are a bit too small for this build, and the 8.5 are a bit large.
Im still going with a 1/8 savage xl body so it should look kinda factory, kinda like if hpi built a savage solid axle monster truck.
NorthernNightmare
Post by NorthernNightmare » Mon Sep 11, 2017 7:17 pm
Other kyosho mad force builds, and a fo-xx that has custom long travel setup (very plush)
IMG_2823 - Copy.JPG (153.73 KiB) Viewed 673 times
IMG_2689 - Copy.JPG (197.82 KiB) Viewed 675 times
Last edited by NorthernNightmare on Sat Nov 18, 2017 6:34 pm, edited 4 times in total.
NorthernNightmare
Post by NorthernNightmare » Tue Sep 26, 2017 5:12 pm
Hey guys I almost got this tube unit in a roller so check it out 8)
The air shocks are true functioning no spring inside, there will be 2 per corner, full adjustable so lots of tuning involved :shock:
Love how the radius arm mounts and trans cradle worked out, just gotta button up the upper shock mounts and all the small stuff now. TTR parts are on the way!
Last edited by NorthernNightmare on Sat Nov 18, 2017 6:37 pm, edited 3 times in total.
NorthernNightmare
Post by NorthernNightmare » Tue Sep 26, 2017 5:16 pm
Few more jumbo tires
NorthernNightmare
Re: Extreme Kyosho Monster Tuber Build
Post by NorthernNightmare » Sat Nov 18, 2017 6:04 pm
Getting closer to the first test run
Post by GRAVETXT-1 » Sat Nov 18, 2017 8:03 pm
Man that is so cool cant wait to see a body on this truck very clean build too 8)
NorthernNightmare
Post by NorthernNightmare » Wed Nov 22, 2017 6:03 am
Thanks again :)
I just gotta do the body mount setup, and choose the final powder coat color. I think i will do catapillar yellow or something industrial like that. Including all the metal tie rods, motor plate, beadlock rings (theres lots of metal really) oh and the swaybar setup (witch i have yet to test fully) but you can see the mounts for it at the back half.
The only xl body available right now is the gmc top kick, not my style at all for this build but i ordered one anyway haha
The shocks are very trick, 10 by 100 and have 4mm shafts, you can set the main and sub air pressures to get some crazy dampening effect, they hold air over night and off some big drops! Im also testing with some slightly bigger bore cylinders that are working even better (insert lots of air shock tech here) blah blah blah
In short, it all works just fine 100mm of travel over 75mm in just up travel thats more than a 1/5 baja 5b. Even with all that travel the drive shafts are dead straight most of the arc.
The math teacher can kiss my butt i did some red nek tech and something went right :lol:
NorthernNightmare
Post by NorthernNightmare » Wed Nov 29, 2017 6:26 am
Just waiting on the powder coat but already have started a few cool new builds :lol:
Worth posting :thumbsdown: ..... :thumbsup: , kind slow as far a MT's posts and builds are concerned. Why so slow yikes
:butthead: facebook :butthead:
Users browsing this forum: No registered users and 11 guests
