Cpe Terminator 2k15
GodsLiLMistake
Cpe Terminator 2k15
Post by GodsLiLMistake » Sat Apr 08, 2017 10:41 pm
Well here is my Cpe Terminator 2k15 in all its glory. I started off with 0 parts no axles or anything :butthead: . In the pictures are my carpet wheel and tire set up. Let me know what you guys think!! :nana:
Base: Clodbuster
Chassis: Cpe Terminator 2k15
Shocks: GMade XA 103mm Aeration Shock
Esc (x2): Castle sidewinder sv3
Motor (x2): Castle 4 pole 5700kv
Pinion (x2): 13 Tooth steel Robinson Racing
Servo: Spektrum S6230 Digital High-Torque
Lipo: Speedzone 7600mAh 75c
Radio: Futaba 4PX
Receiver: Futaba R304SB 2.4GHz FHSS
Wheels: Jconcepts Tribute (gray and black)
Tires: Jconcepts Firestorm(gold)Indoor, Jconcepts Renegades(blue)outdoor
Body: Jconcepts 93' F-250
Extras: CPE rear lock out, CPE BTA steering, CPE SS hardware for axles, rc4wd cvd's, full ball bearings, HR axle tubes, HR knuckles.
Last edited by GodsLiLMistake on Fri Apr 28, 2017 1:54 pm, edited 2 times in total.
GodsLiLMistake
Re: Cpe Terminator 2k15
Post by GodsLiLMistake » Sat Apr 08, 2017 10:43 pm
Here is some pictures of my truck rocking the outdoor wheel and tire set up.
Last edited by GodsLiLMistake on Fri Apr 28, 2017 1:58 pm, edited 1 time in total.
lanky
Post by lanky » Sun Apr 09, 2017 1:48 pm
Wow! Now that's a Clod, Awesome Truck! Love the outdoor setup... :thumbsup:
GodsLiLMistake
Post by GodsLiLMistake » Sun Apr 09, 2017 8:27 pm
I drove it for the first time yesterday.... This truck is a rocket ship!!!
Thank you!! I kind of like the look of the bigger firestorm's but maybe on the black wheel.
matt1ptkn
Post by matt1ptkn » Mon Apr 10, 2017 3:09 pm
That's a great looking truck! I really love that body and am looking forward to having the painting finished on mine (I don't like the process of body work - scale or 1:1). I just wish they'd have put an actual bumper on the rear, not just an outline.
So how does it handle? Are you only running one battery?
-Matt
GodsLiLMistake
Post by GodsLiLMistake » Tue Apr 11, 2017 6:51 am
I find painting half the fun :shock: , she still needs a little tuning.. shocks are a little soft. But all and all i think its a contender for racing. Yes im running a single 2s 7600 mAh 75c.
lanky
Post by lanky » Tue Apr 11, 2017 11:17 pm
How is the speed on 2s? what are your motor temps after say 10 mins of run time? I just ordered 2 castle systems, 5700KV, I was planning to run 3s on a 13t pinion. For reference, I have been running the clod on EVX2/ titan 21T 550's on a 19t pinion 3s. It was to slow for my track, ran it 4s, it was about perfect, however motors would get to 190F in about 8 mins.
GodsLiLMistake
Post by GodsLiLMistake » Tue Apr 11, 2017 11:42 pm
On 2s and 5700's it's controllable I haven't tried 3s... I think that will be standing backflip city. As far as temps at the 15min mark they where hot but you could hold them for a good 10 to 15 seconds before it got "to hot to hold". I'm running stock gearing so I do have room to play with gearing if I go for adjustable motor mounts.
Speaking of adjustable motor mount anybody have recommendations?
GodsLiLMistake
Post by GodsLiLMistake » Tue Apr 11, 2017 11:45 pm
Does anybody have recommendations also im looking at 4 Link placement on the chassis what is the Optimum way to have the axle angle setup and everything I am new to tuning 4-link suspension
GodsLiLMistake
Post by GodsLiLMistake » Mon Apr 24, 2017 11:51 pm
So i had my first brake happen on the truck today. I was at the local public track, came off a jump and over corrected causing the truck to nose dive straight to earth. I snapped my CPE BTA carbon fiber tie bar in half at one of the holes in the middle when this happened. Lucky for me when I ordered everything I got a extra one. So now I'm wondering what I can do to make this stronger or if there is another bar that I can get that will work with my cpe servo mount. I did put a kimbrough large servo saver on the truck before this happened.
dubbl-a
Post by dubbl-a » Tue Apr 25, 2017 3:28 pm
First off, your truck is sweet! Love the build.
You can use different steering setups with the CPE servo mount. I started with a behind the axle setup and now run a link setup up front. Iv'e been running this for a while an it's taken some abuse!
GodsLiLMistake
Post by GodsLiLMistake » Fri Apr 28, 2017 12:47 am
I've been thinking of using the carbon bar and making one out of aluminium or using steel.
GodsLiLMistake
Post by GodsLiLMistake » Fri Apr 28, 2017 12:51 pm
Quick jumping video my fiance took for me
https://youtu.be/udY8H_4bdME
lanky
Post by lanky » Sun Apr 30, 2017 12:34 am
That thing is wicked! I'm officially on the hunt for a race chassis!
GodsLiLMistake
Post by GodsLiLMistake » Tue May 02, 2017 2:08 am
Thanks I'm in love with this truck, I'm still adjusting the 4link and it's hooking up better and better with the tires breaking in. I've thought about a gearing change but I'm happy where it's at right now. I'm sure if I started racing gearing would be a bigger factor. On a side note I found some thin steel at work. I'm going to make a new tie bar for the BTA or make a brace for the carbon fiber tie bar.
