Son of Tiamat build + The Cylon build
flofox
Post by flofox » Sun Oct 27, 2013 10:52 pm
hello everbody
I came across a picture of Tiamat about 1.5 years ago
and sort of fell in love with it
Tiamat example
So i wanted to build my own Tiamat, wich i will start now
I will call it, at least for now, "Son of Tiamat"
maybe you think that name sucks or is stolen
but i want that name, first to honour Tiamat
also i thougt it sounded a little serial killerish (like son of sam orso)
and it's also MY truck ,so i will call it whatever i want !
I will also build it in a chrome/silver version
because i came across this cabin
chrome cabin
WP_000196 (Small).jpg (104.83 KiB) Viewed 2448 times
chrome cabin2
WP_000195 (Small).jpg (99.86 KiB) Viewed 2448 times
I think i will build two actually because i also bought this cabin fairly cheap
red cabin
WP_000417 (Small).jpg (76.47 KiB) Viewed 2448 times
I will offcourse do some things different, i dont want a clone
First of all ,it will be cheaper
like standard size servo's en cheaper motors
also i will build a U/box shaped chassis
for a more easy build and to be more rigid
also the size will be a little different, well only one inch shorter actually
I estemate the build will be 3 or 4 months
so expect it to end up around 6 or 7 months (LOL)
I also lost my job ,so money is very thight right now
(sorry for the bad english , i am a stupid dutch man)
flofox
Re: Son of Tiamat build
Post by flofox » Sun Oct 27, 2013 11:04 pm
So i started the build yesterday
I have started to build two chassis
chassis 2
WP_000423 (Small).jpg (94.33 KiB) Viewed 2443 times
chassis 1
WP_000422 (Small).jpg (96.53 KiB) Viewed 2443 times
theyre still rough ,and will finish them later
before i start the lower frames
but i am happy with how they turned out so far :thumbsup:
i plan to do more this week
but because i lost my job
i am very busy , with applying for financial support
and offcourse look for work
i also have a 3 year old son and a 4 month infant boy
I also have to clean this mess in the barn first :lol: :lol:
rotzooi
WP_000418 (Small).jpg (101.97 KiB) Viewed 2443 times
Ps I also have to give big credits to sicnme !
i took a lot of measurments of the 6x6 frame i bought from him
without it it would take a lot more figuring out
Post by SFC K » Sun Oct 27, 2013 11:08 pm
This is going to be epic man! You seriously need to clean that work space though! :lol:
flofox
Post by flofox » Fri Nov 01, 2013 2:51 pm
ok have continued a little bit
first i cleaned my workspace
cleaned
WP_000430 (Small).jpg (73.53 KiB) Viewed 2396 times
then worked on the chassis some more
they will be partially rivited en partially screwed
chassis 1
WP_000433 (Small).jpg (75.39 KiB) Viewed 2396 times
chassis 2
WP_000435 (Small).jpg (67.59 KiB) Viewed 2396 times
chassis 3
WP_000437 (Small).jpg (64.93 KiB) Viewed 2396 times
chassis 4
WP_000442 (Small).jpg (93.2 KiB) Viewed 2396 times
chassis 5
WP_000443 (Small).jpg (84.82 KiB) Viewed 2396 times
these are the shocks
one chassis will have 4link set up with hpi shocks (like tiamat)
the other one wil have standard links and shocks(clodbuster)
shocks
WP_000439 (Small).jpg (84.2 KiB) Viewed 2396 times
weeb_beano
Post by weeb_beano » Fri Nov 08, 2013 10:12 pm
Hi there! I just saw this thread and what can I say... i'm thrilled and wish you the absolute best of luck in getting these trucks built!
The more 6WD trucks, the better. There aren't too many of us weir- uh guys out there :)
I like the approach of the chassis being almost a "bathtub" - it gives for a nice solid build and leaves lots of room for internal gear.
Those bodies are pretty sick too. I wasn't a fan of the metallic body originally but seeing yours here it looks a lot nicer than I imagined.
The one thing I should caution you on with those long HPI Savage shocks - you will need to make a lot of room to keep them happy. I had to mount mine on very high shock towers, and also needed push them out so wide that the shocks did not hang down straight. On Tiamat they cant inwards at a slight angle. You might get away with only pushing them up and out because your chassis is narrower than mine - but I felt like pointing this out just in case.
I had to also widen the track as well to get these shocks to fit. Even now I am a bit concerned that they are too close and might tire rub.
Again, best of luck in this project, and good luck finding a new job too! It looks like you're already well on your way in getting this going and I like what I see.
flofox
Post by flofox » Fri Nov 15, 2013 12:47 pm
hello weeb
thx for the reply
I liked the shock towers you build on Tiamat
It was part of the appeal for Tiamat to me
so i wil sort of copy them too
If i am not happy with them ,i will replace(modify) them
I also have continued a bit more
Because i dont use an aeromax frame to mount the body
I must mount the body directly to the chassis
I am now in the process of making the body mounting brackets
chassis
so i was struggling a bit to find the right height to mount the body
but i will go with this height
cabin pre fit
Saw this thing on ebay ,and bought it
ebay2
ebay1
Will take it apart and use for parts for the 6x6's
both axles will be used as front axles for both of the 6x6's
it came with 20kg steering servo's and with a nice bumper so the steering servo is protected
I will use the links for the Son of Tiamat
more coming soon
flofox
Post by flofox » Sun Nov 24, 2013 10:44 pm
I have continued some more on the chassis
finished the brackets to mount the cabins, and the battery packs
brackets 1
WP_000492 (Small).jpg (72.83 KiB) Viewed 2228 times
brackets 2
WP_000503 (Small).jpg (102.69 KiB) Viewed 2228 times
cabin mounted
WP_000501 (Small).jpg (90.61 KiB) Viewed 2228 times
brackets 3
WP_000522 (Small).jpg (77.73 KiB) Viewed 2228 times
I am now working on the rear lights and battery covers
one chassis will have the same rear lights as Tiamat(from tamiya)
and the other one i will give a wedico rear bumper
not 100% sure about that,
but we will see how it ends up
flofox
Post by flofox » Tue Dec 03, 2013 11:30 pm
did some more work
because the shock mounting differs on each chassis
I have concentrated on the chassis with the normal clod shocks for a bit(more easy to build because of stock clod measurements)
chassis
this chassis is almost finished now actually
I took the brackets to mount the cabin off
so i have room to work on the esc's and other electrics
maybe i will do a mock up to see how it will become
I have also brushed the whole chassis with scotchbrite
also the bolts will be replaced with allan bolts
I orded them on ebay(from china)
I had to cut the third lower frame a bit more on the top side to make clearance for the battery cover
also will this need flush mounted (allan) bolts from the indside
so i have room on the inside of the chassis for the battery packs
when this chassis is finished ,i will stop working at it
and will continue working on the Son of Tiamat chassis
(eh ,so this chassis is for the Cousin of Tiamat, or whatever it will be called)
flofox
Post by flofox » Fri Dec 06, 2013 11:39 am
hello again
did some more work
installed the rear lights on both trucks
rear lights 1
WP_000535 (Small).jpg (89.43 KiB) Viewed 2126 times
rear lights 2
WP_000536 (Small).jpg (89.13 KiB) Viewed 2126 times
also i took this thing apart
race chassis 2
race chassis 1
and converted it into two front axles for both the trucks
front axles
WP_000528 (Small).jpg (99.91 KiB) Viewed 2126 times
although i am not very happy with them!
I can see some cracks on the axle tubes where the links are mounted
also i found out after recieving the race chassis
that the diffs are glued together for crawler purposes!(aargh!)
so i think i will take them apart en repair everything
not happy with that
because i paid big bucks for the race chassis
now i have to spend more money and time on it
Post by charliechristmas58 » Fri Dec 06, 2013 5:54 pm
Where did you get those servo guards/bumpers ?
flofox
Post by flofox » Fri Dec 06, 2013 10:52 pm
charliechristmas58 wrote:Where did you get those servo guards/bumpers ?
Read the whole thread first dude!
They came with the race chassis i bought on ebay
So i dont know what brand they are
sorry
Post by charliechristmas58 » Sat Dec 07, 2013 5:13 am
Thats to much trouble :lol: I like to look at photos :lol:
flofox
Post by flofox » Tue Dec 10, 2013 9:03 pm
the axles for the first truck are finished
steering servos are on them ,ball bearings etc
the front axle has been completely overhauled
glued diff has been taken out, axle tubes replaced
and some bearings replaced
WP_000592 (Small).jpg (117.99 KiB) Viewed 2066 times
WP_000593 (Small).jpg (120.49 KiB) Viewed 2066 times
because i cannot name every truck like this i build "Son of Tiamat" or "Daughter of Tiamat"
I will name the second truck for now "Big Sis"
because its the sister of SoT :roll:
Or does that name sound stupid orso in english? :?: :?
Btw today the stainless allan bolts have arrived from china :thumbsup:
so i will finish the chassis of the second truck soon
and will do a mock up of the truck to see how it will look :supz:
flofox
Post by flofox » Fri Dec 20, 2013 1:19 pm
did the mock up last weekend for the second truck(eh, so this is now the first?! :) )
Its far from finished though, the inside is still completely empty
the fifth weel is not attached yet<although useless , i think i will make it a working one :P
de upper shock mounts need different bolts, the ones used for the foto shot are too short
the upper frame to mount the cabin will have to be removed to do the wiring
I used cheap 17t motors,
cheap china alloy shocks,
cheap china servos for the two rear axles
And i will use cheap china esc's
and a cheap lighting kit
Maybe i will add some led's(strips orso)
It looks like its sitting a little higher then Tiamat?
I can lower it a bit more(only 10mm), what do you guys think?
Also i dont like the name i chosen first (big sis) sounded a little Super Dee Duper-ish in my opinion [-X
Because this truck is the brother of 'Son of Tiamat' , i will call it 'little brother' from now on(maybe lil bro?)
Let me now what you guys think,
and let me know if you like it !!!
weeb_beano
Post by weeb_beano » Sat Dec 21, 2013 4:33 pm
Wow, you are making pretty good progress with these builds... i think the difference in height would be that Tiamat has a lower ride height. I cant tell 100% from the angle of the photos but that is my guess. I can take some shots at a flat angle with a longer focal length on the lens so you can compare and decide. I'm on the road now but will try to post for you later today.
As for the names i cant offer much. To be honest the first thing i thought of when i saw the chromed body was 'Cylon' :)
Users browsing this forum: No registered users and 0 guests
