Carbon Fiber Chassis Part 1
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 12:57 am
RE: viewtopic.php?f=6&t=23826
Hello members I have started to build this chassis. After reading this good article that is listed above. I started over and by doing this, I have done a lot of reading and asking may questions on this subject of the pros and cons.
But as of now I am going to ask you all on the pic's that are listed below within this link. The Red Dragon :arrow: ( viewtopic.php?f=2&t=24521 )
told me that I have two brace support for the front and rear of this chassis. And I am not going to do jack until I hear from all of you.
I really took my time on using my drill on this. As you see,I used masking tape to set up my shock mounts. Chuck told me by text that I should have them set up at a half inch.
As you see within this pic. Both of the aluminum braces are at 4.5 inches long. But the one on top is 1.5 inches wide. Where and how should I place these braces to support the shock mounts?
todd ritchings
Re: Carbon Fiber Chassis Part 1
Post by todd ritchings » Mon Feb 21, 2011 2:50 am
Take a look at this zilla bulid
http://clodzone.com/?p=205
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 3:12 am
I see that,but I am still lost :? .
I would like to mount this,and the small one like this.
The Red Dragon
Post by The Red Dragon » Mon Feb 21, 2011 6:17 am
the big plate looks good at the back. a bolt hole between the two bolt holes in the frames and a bolt hole just behind them so that strengthens everything. the smaller plate i would run on top to allow for parts moving in suspention travel. tho i dont know how high off the ground you plan to run the truck. i always ran my trucks pretty low. as you can see from the picture below.
R.I.P Braden Mare. you where a true friend and will be missed.
Rides:
JunkYard Nautilus....in dry dock for repairs
clodbuster (bigfoot 8 ) (upgraded to 12v lead acid sealed battery)
HPI RS4 MT (dead, brushless killed it)
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 10:24 am
The Red Dragon wrote:the big plate looks good at the back. a bolt hole between the two bolt holes in the frames and a bolt hole just behind them so that strengthens everything. the smaller plate i would run on top to allow for parts moving in suspention travel. tho i dont know how high off the ground you plan to run the truck. i always ran my trucks pretty low. as you can see from the picture below.
so what you are saying is to run both larger plates on the bottom,and run the other two on the top?
because i wanted to run it with the larger plates on top,and small ones on the bottom for better support on the cpe lift-kit.
Post by Budhatrain » Mon Feb 21, 2011 2:30 pm
That should be fine- nice and rigid. Are you going to bold them together or durafix it?
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 2:42 pm
Budhatrain wrote:That should be fine- nice and rigid. Are you going to bold them together or durafix it?
:confused: what do you mean by durafix?
Post by Budhatrain » Mon Feb 21, 2011 2:48 pm
http://durafix.com/index.html?gname&gcl ... 4Aodo2xecQ
looks like all you need is a torch. here's a topic on another forum and the guy used it. Looks real solid and different- I likey.
scroll down to you see his fab of chassis and you'll see.
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 4:38 pm
i cant read because i am using my t-mobile dash. i have to look at it when i get home. but tell me what it does? and did you used this product on any of your projects ?
Post by Budhatrain » Mon Feb 21, 2011 4:42 pm
it's like aluminum weld- I have not used it, but will if the occasion comes
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 5:12 pm
Budhatrain wrote:it's like aluminum weld- I have not used it, but will if the occasion comes
Ok,it's like jb weld. but for aluminum.
The Red Dragon
Post by The Red Dragon » Mon Feb 21, 2011 5:18 pm
no no. the thick plate on top is good. if i was building the truck the thick and skinny plates would both be top side to avoid suspention travel
Rides:
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 7:53 pm
The Red Dragon wrote:no no. the thick plate on top is good. if i was building the truck the thick and skinny plates would both be top side to avoid suspention travel
ok, now what about 3/4 inch one on the bottom? use it,or would it give me problems with my suspension?
Post by Budhatrain » Mon Feb 21, 2011 9:19 pm
durafix is not like JB weld... you still need a torch- it's brazing
FlashGordon1
Post by FlashGordon1 » Mon Feb 21, 2011 10:25 pm
Budhatrain wrote:durafix is not like JB weld... you still need a torch- it's brazing
well i don't think that i am going to need that product. my chassis rails are made out of carbon fiber.
Users browsing this forum: Baidu [Spider] and 9 guests
