Keeping LEDs in headlight buckets
Talk about what bodies fit, as well as your painting, and other body techniques here.
LAV25
Post by LAV25 » Mon Jan 16, 2017 7:46 am
Sorry if this has been addressed before, but I couldn't find a thread for it.
What's the best way to secure an LED into an older (Clod, Bullhead) headlight bucket? The newer Tamiya models like the TT-01 have a screw-fixed bracket that keeps the LED from slipping backwards out of the bucket, but the older models just have a hole to slide the bulb into. They're about 5mm or 3mm, but not tight enough to hold fast under the pounding of offroading. I was thinking hot glue might work, Shoe Goo or CA would seem to be too permanent.
Suggestions?
Yeah, I'm the guy you saw hammering in screws with a pipe wrench, why do you ask?
132NHAF
Re: Keeping LEDs in headlight buckets
Post by 132NHAF » Mon Jan 16, 2017 3:43 pm
I'd say hot glue, or Shoo Goo. Don't think the CA glue will hold up over time.
Scott T
Stickers...Get your ClodTalk stickers here: viewtopic.php?f=2&t=25953
It's not WHAT toys you play with, but that you play with toys at all that is important.
mavrick0
Post by mavrick0 » Tue Jan 17, 2017 12:52 am
Shoe goo would be your best bet. Hot glue doesn't adhere very well and with the banging around it'll come loose.
A off roader may be able to jump and run around a track. A on roader may be able to run circles around the road but a monster truck will run over anything and everyone.
