View unanswered posts | View active topics It is currently Wed Jun 19, 2013 6:16 pm
Please help support ClodTalk.com! Any contribution helps!! Donate towards my web hosting bill!
Reply to topic  [ 15 posts ]
 How do to "shadow" designs?
Author Message
I may have missed it but I didn't see anything about it,
so, how would you do shadow designs. I am not sure if that is the proper name for it, but if anyone knows what I am talking about any help would be apreciated.
Sun Jan 23, 2005 2:28 am
Profile WWW
Post
I would use a pearl color because they are see-through :wink:
_________________
yaddiddameean
Sun Jan 23, 2005 3:49 am
Profile WWW
Post
I was looking around and I guess they are called Ghost paint jobs, and the main thing seems to pick two closly match colors and make semi transparent. Is that right?
Sun Jan 23, 2005 5:27 am
Profile WWW
Post
Yeah my bro just did one on his B4 body :wink:
_________________
yaddiddameean
Sun Jan 23, 2005 5:50 am
Profile WWW
Post
Here you go this makes it look killer it's the little details
http://www2.towerhobbies.com/cgi-bin/wt ... XCY28&P=ML
_________________
yaddiddameean
Fri Jan 28, 2005 4:51 am
Profile WWW
Post
I was taling to TIER the other day and he said thats what I should use...though I am not sure if I want a shadow design anymore....Thanks though :D :D
Fri Jan 28, 2005 10:27 pm
Profile WWW
I'm guessing your talking about droop shadows. If you are painting flames or whatever your design is. Fist mask out your design and the fill your airbrush with balch or a darker color of your maincolor and spary a light coat along the edges you want to give the appearence of a shaddow. Then paint your main color follwed by the part you have masked off. See some examples in my gallery on RC10b4.com here http://www.rc10b4.com/gallery/showgalle ... ppuser/628
or there is a good pic here as well: http://www.clodtalk.com/viewtopic.php?t=9921&highlight=
I hope this is what you were looking for or I wasted some time here :)
_________________
Konichiwa Bitches!
Tue Feb 01, 2005 4:36 am
Profile ICQ YIM WWW
Post
Not sure what droop shadows are but hopefully this pis clears up what I want to do.
Tue Feb 01, 2005 10:30 pm
Profile WWW
Post
I see it The pearl colors look like that, but more sparkly! :D :wink:
_________________
yaddiddameean
Tue Feb 01, 2005 11:03 pm
Profile WWW
Post
That would be called ghosting. I'll post more on how to do this when I have a few more min of time. It's easier than droop shadows though.
Josh
_________________
Konichiwa Bitches!
Wed Feb 02, 2005 2:28 am
Profile ICQ YIM WWW
Post
Wow sorry it has been a long time since I last made a post. Ok so for ghosting... It's actually very easy but it does require mixing paints in most cases and an airbrush. The trick is to mix the paint one or two shades lighter than the main color. The just spray the outer edges of your design. Let that coat dry and spary the rest with the same color as your main color.
If you going about this the old rattle can way. You can still get a decent ghosting affect when your using lighter metalic colors of candy colors work the best. First mask off the design, flames if you will. The spray your main color. Candies will ned several light coats. Make sure you note the numer of coats you used though. Let your candy color dry very well. Next back your candy color. Backing is normally done with silver or gold cor most candy colors. Let that dry all the way then remove your masking. Then spary the masked area with a few less coats of the same candy color you used for your main color. Let this dry well. Next time to back the candy color. This can be tricky though because you only want to back the edge where you flames meet your main color and not cover the whole flame design. Once that layer is dry hit the rest of the area that is not backed with a few more coats of candy to match your main color. Let that dray and finnish off with your backing color.
This is a sure way to get a killer paintjob even wirh the use of rattle cans. I hope this is of some help to you guys. If you have any questions please PM or e-mail me I'll be happy to try to help you out.
Josh
_________________
Konichiwa Bitches!
Fri Feb 18, 2005 11:06 pm
Profile ICQ YIM WWW
Post
Here is an example of droop shadows. Look for the shadows behind the flames on this Fairlady Z body I painted.
_________________
Konichiwa Bitches!
Fri Feb 18, 2005 11:12 pm
Profile ICQ YIM WWW
Post
_________________
Konichiwa Bitches!
Profile ICQ YIM WWW
Post
Sorry about the double post :(
_________________
Konichiwa Bitches!
Fri Feb 18, 2005 11:13 pm
Profile ICQ YIM WWW
Post
Something like this? Pearl backed with black.
Tue Mar 01, 2005 5:44 am
Profile WWW
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Help support ClodTalk.com
Donate towards my web hosting bill! Help support this forum!  Any contribution
is greatly appreciated!
Click here for more information!
Green Web Hosting! This site hosted by DreamHost.
This forum is supported by:
Powered by phpBB® Forum Software © phpBB Group
Designed by ST Software for PTF.
