How To Tip: Proline Brawler RIT Dye Steps
SWMS
Post by SWMS » Sat Apr 23, 2016 3:17 am
The following is a How To describing how to dye Proline Brawler wheels with RIT Dye.
***Disclaimer: This is the technique I used which result in successful coloring. Perform at your own risk.***
Okay, now on to the good stuff! :thumbsup:
STEP 1:
Gather your stuff.
Materials:
- One Pot
- One Box of RIT Dye
- Brawler Wheels
- Tongs
- Water
- Access to a Stove
- Paper Towels
When selecting a pot for boiling water and the RIT dye, be warned that the RIT dye can stain your pot.
So it is best to use a very old pot or buy one specifically for this project.
I purchased the pot in the picture from Wally World for approximately $8.
The picture shows two boxes of RIT but I only used one. Each box cost a little under $2.
STEP 2:
Boil the water.
STEP 3:
After the water reaches boiling point, drop the temperature down to a simmer.
Now add the box of RIT dye. Be careful not to splash. This stuff can stain.
STEP 4:
Using a pair of tongs, lower each wheel into the pot.
With the size of pot I used, I was able to do one pair of wheels at a time.
Let the wheels sit for a minimum of 30 minutes.
After the 30 minute mark, I checked the wheels to verify the color took. I decided to let them sit in the dye for 20 minutes more.
Adjust as needed. Some colors may need longer.
STEP 5:
Remove wheels and allow to dry on paper towels.
Remember that this stuff stains, so be careful with drops and bleed through of the paper towels.
STEP 6:
Celebrate how freaking awesome they came out! :thumbsup: :thumbsup: :thumbsup:
Re: How To Tip: Proline Brawler RIT Dye Steps
Post by andymac0035 » Sat Apr 23, 2016 11:25 pm
Nice write-up! =D> :thumbsup: =D>
Post by SFC K » Sat Apr 23, 2016 11:26 pm
andymac0035 wrote:Nice write-up! =D> :thumbsup: =D>
X2! =D>
SWMS
Post by SWMS » Sun Apr 24, 2016 12:38 am
Thanks guys! This was a fun little project.
Post by CowboyClod » Sat Jun 25, 2016 1:12 pm
One question? what temperature did you set it too when simmering.
SWMS
Post by SWMS » Mon Jun 27, 2016 8:13 pm
That's a tough one to answer. I did not really measure the temp. I set the temp knob to 4/5 for simmering, but I'm not really sure what that equates to in temperature units.
Post by CowboyClod » Tue Jun 28, 2016 2:19 pm
KingKlod wrote:That's a tough one to answer. I did not really measure the temp. I set the temp knob to 4/5 for simmering, but I'm not really sure what that equates to in temperature units.
Alright that does it
:banned: :mrgreen:
