Body Shells with wheelbase 13,xx''?
The Knight
Post by The Knight » Thu Feb 18, 2016 8:52 pm
I'm searching for pickup monster trucks body shells (not painted, not holed) which have 13,xx'' or ~ 35cm wheelbase.
I know tamiya terra crusher, but this body have a big hole in back.
Do you know someone?
Greets from Germany!
The Blackfoot III
percymon
Re: Body Shells with wheelbase 13,xx''?
Post by percymon » Thu Feb 18, 2016 10:30 pm
I just bought a Killerbody Rubik shell for my mod Clod - they do numerous versions from unpainted , semi painted, printed to fully painted. UK modelshop link but you can see the various designs ...
http://www.modelsport.co.uk/index.php?s ... ik&x=0&y=0
wheelbase is quoted at 325mm (12.8" in old money ;) ) but what appealed to me was the relatively narrow width of 175mm (6.9") which is pretty narrow compared to the usual suspects of the Pro-line truck shells, which being more 1/8th scale are often too wide for a narrow track Clod, forcing either a high mounted shell or axle wideners to get wheel clearance.
I've not had chance to try it on my carbon Terminator chassis but i'm hopeful it'll be near enough.
The Knight
Post by The Knight » Fri Feb 19, 2016 10:09 pm
Parma have released a new 1/8 Body For F150 XLT 52cm long! This could be fit. But nowhere is written the size of wheelbase.
Parma havn't listed it on website.
http://www.rcplanet.com/Parma_1_8_F150_ ... ar1212.htm
The Blackfoot III
Post by 132NHAF » Sat Feb 20, 2016 3:19 pm
When you say 13,XX, do you mean larger? XTM Mammoth-15" WB. I've used two and have another in the bag I haven't touched.
The Knight
Post by The Knight » Sat Feb 20, 2016 4:50 pm
What i axectly need is 35cm wheelbase. 34cm would be also possible.
I do not find an pickup bodies in this size. But I have found a lot of 1/10 short course body shells which have 33,xx cm WB. Using this bodies will give the truck a look like Bigfoot #18. So I will try to find some useful short course bodiy shells. ;)
The Blackfoot III
Re: Body Shells with ee13,xx''?
Post by 132NHAF » Sun Feb 21, 2016 4:14 pm
I suppose you could use a shorter body and open up the wheel wells. That way you can use the top apex and shift it front or back as you need to.
The Knight
Post by The Knight » Sun Feb 21, 2016 7:34 pm
132NHAF wrote:I suppose you could use a shorter body and open up the wheel wells. That way you can use the top apex and shift it front or back as you need to.
I also think so. Do you know a good american page, which sell a lot of 1/8 bodies?
The Blackfoot III
Post by 132NHAF » Mon Feb 22, 2016 6:15 pm
Try this: http://www.hobbypeople.net/index.php/rc ... odies.html
6x6_BigDollars
Post by 6x6_BigDollars » Wed Feb 24, 2016 3:04 pm
CHECK THIS PLACE THEY HAVE 1/12,1/10 I THINK 1/8 BUT THEY MARK
HOW LONG AND HOW WIDE AND HOW TALL AND THEN THE WHEEL BASE
http://www.rccarkings.net/bodies.htm HOPE YOU CAN FINE SOME THING THERE.
Message from clodtalk admin:
