Pro-Line F-650 body on a Clod??
Echarlie
Post by Echarlie » Wed Dec 02, 2015 12:03 am
Hello. Newb here. Can anyone tell me if the Pro-Line F-650 body will fit on a Clod? Pictures would be even better!!
Re: Pro-Line F-650 body on a Clod??
Post by SFC K » Wed Dec 02, 2015 12:06 am
Yeah, it will work with extended wheel base. Might not look right on a stock Clod chassis build though.
viewtopic.php?f=46&t=30352&p=289893&hilit=F+650#p289893
Echarlie
Post by Echarlie » Wed Dec 02, 2015 12:09 am
I've got the sassy chassis and the clodzilla IV chassis. Would either of those work with the body?
I really love that body.
Post by SFC K » Wed Dec 02, 2015 12:11 am
It will depend on your current wheel base. WB on that body is 13.8 inches long.
Length: 19.9" (505mm)
Width: 7.1" (180mm)
Height: 5.1" (130mm)
Wheelbase: 13.8" (350mm)
Echarlie
Post by Echarlie » Wed Dec 02, 2015 12:15 am
Not exactly sure what that means. Just got my Clod.
Post by SFC K » Wed Dec 02, 2015 12:18 am
If you measure where the wheel nuts are from wheel to wheel (center to center) that is what your wheel base is. Those dimensions posted above are the body dimensions...
Echarlie
Post by Echarlie » Wed Dec 02, 2015 12:23 am
So in order for the body to look correct I need to make the wheelbase of my Clod 13.8"?
Post by SFC K » Wed Dec 02, 2015 12:38 am
It does not have to be spot on but in the ball park. With Clod tires, IMHO you can have a longer wheel base and still look good. Its when the WB is shorter they tend to look funny.
Post by andymac0035 » Sun Dec 06, 2015 3:52 am
This is an extended stock chassis with that body:
(a stock length body would be way to short unless you 4 linked it with longer than stock links)
and here is a clodzilla II with it also
rc-pics 154.jpg (159.21 KiB) Viewed 1015 times
Echarlie
Post by Echarlie » Sun Dec 06, 2015 3:57 am
Thank you for the pics!
I'll have to see what I can do with either the sassy chassis or the clodzilla IV.
Echarlie
Post by Echarlie » Tue Dec 15, 2015 1:34 pm
so if my wheelbase is currently only 12 1/2" how can I extend it to the 13.8" for the F650 body?
Keep in mind, this Clod that I purchased was / is set up for pulling. It runs the Sassy Chassis but I also have a Clodzilla IV chassis I could use.
Echarlie
Post by Echarlie » Tue Dec 15, 2015 8:07 pm
Measured the wheelbase again and its 13". Not 12 1/2". So I need to extend it 3/4" for the F650 body.
How would I accomplish this?
Post by andymac0035 » Wed Dec 16, 2015 6:10 am
Echarlie wrote:Measured the wheelbase again and its 13". Not 12 1/2". So I need to extend it 3/4" for the F650 body.
Longer links to move the axles farther apart, giving you the wheelbase you desire.
Echarlie
Post by Echarlie » Wed Dec 16, 2015 10:22 am
Hate to be stupid, but where can I purchase them?
Post by andymac0035 » Wed Dec 16, 2015 3:57 pm
I'm pretty sure CPE still makes custom length links.
