soaking a body
sunseri4819
soaking a body
Post by sunseri4819 » Mon Oct 28, 2013 7:15 pm
Im gonna use the simple green concentrate to remove the paint. When you soak your body do you have to completly submerge the body in the liquid or can you soak paper towels and lay them on there and get the effect?
slapshot1979
Re: soaking a body
Post by slapshot1979 » Mon Oct 28, 2013 7:23 pm
both will work, but ideally completely submerge would work better but to find a container to do so is hard without mass amounts of simple green. you can also add objects under and around body to increase the 'volume" and bring level higher
sunseri4819
Re: soaking a body
Post by sunseri4819 » Mon Oct 28, 2013 7:48 pm
Never thought about adding in objects.
Re: soaking a body
Post by charliechristmas58 » Mon Oct 28, 2013 9:27 pm
I used breakfluid and i have it in a container thats i can put the lid on and reuse it when i need it . it never gets old you just have to strain it now and then
