And so it begins....
HoosierClod
Post by HoosierClod » Fri Jan 01, 2016 3:26 am
I started on my quest to machine aluminum axles for my Clod. I've been wanting to do this since I bought it nearly 20 years ago. Axle tubes are first, followed by the "C"s on the tube ends, steering knuckles, and eventually, gearboxes. I also plan to make a set of aluminum 2.2" beadlock wheels.
The tubes need the bearing bores finished and mounting holes drilled and they will be done.
Adam
Re: And so it begins....
Post by SFC K » Fri Jan 01, 2016 2:49 pm
Wow! Nice work Adam! Did you say you are going to work on gear boxes too? :shock:
HoosierClod
Post by HoosierClod » Fri Jan 01, 2016 3:15 pm
Thanks. I would eventually like to make gearboxes, but that will probably be a while. I want to design the boxes to use smaller metal gears so that the boxes themselves can be smaller for better ground clearance.
Adam
HoosierClod
Post by HoosierClod » Fri Jan 01, 2016 10:05 pm
Started on the knuckles today. The steering arms will be bolt-on.
Adam
Skinner
Post by Skinner » Fri Jan 01, 2016 11:59 pm
:shock: :twisted: nice!! You may be the new vendor for clod parts! ! ;)
~Pat~
HoosierClod
Post by HoosierClod » Sat Jan 02, 2016 7:38 pm
Skinner wrote::shock: :twisted: nice!! You may be the new vendor for clod parts! ! ;)
Thanks. These will be the only set I'm making. I might consider it if I had a CNC lathe and mill, but not with my antique equipment.
Adam
HoosierClod
Post by HoosierClod » Sun Jan 03, 2016 12:44 am
This concludes the lathe portion of the program.
Bearing bores are done and now they're ready for the mill.
Adam
Post by Sixtys Guy » Sun Jan 03, 2016 1:38 am
Wow, I'm impressed!
HoosierClod
Post by HoosierClod » Tue Jan 05, 2016 3:41 am
Thank you.
I'm thinking of going with a worm gear setup in my gearboxes. I can get the same 30:1 ratio that the stock gearing gives with only 2 gears. I may go with 2 more gears before the worm gear to give the option of changing gearing. The worm gear setup would not be ideal for a normal monster/ basher due to the fact that a worm gear setup can not be easily back driven so it would not coast when letting off the throttle. It is ideal for a crawler though since it would work as brakes to keep the truck from rolling and keep it in place when the throttle is released. I found the perfect gears that would only require minimal machining to adapt to the Clod axles.
Adam
Post by Sixtys Guy » Tue Jan 05, 2016 11:24 am
Cool! Dare to be different!
SWMS
Post by SWMS » Thu Jan 07, 2016 2:40 am
Very nice job! I love to see folks make their own things.
rex21
Post by rex21 » Thu Jan 07, 2016 3:01 am
Nice work sir!
I hear you about making only one set with manual machines. I have made some of my parts for others, but it turns into work and not a hobby anymore.
Skinner
Post by Skinner » Fri Jan 08, 2016 12:17 am
Interesting concept on gearcase set up :popc
~Pat~
