Tube frame
Re: Tube frame
Post by vwjuice » Sun Jan 10, 2010 5:26 am
Go with the 55t. 75 will be really slow.
NOUSEFORANAME
Re: Tube frame
Post by NOUSEFORANAME » Sun Jan 10, 2010 4:26 pm
lipbr302 wrote:Can you just use a portable torch to braze like you would find at the hardware store?
Yes, but use actuall brazing fuel, propylene etc, not those small butane torches.
Re: Tube frame
Post by Halgar » Sun Jan 10, 2010 5:08 pm
The twin bottle hobby torch you'll find at Evil Orange and other box stores will work fine, you will go through some fuel though. There is a review here on it. From this info, specialty gas isn't necessary because you're mixing oxygen with the mapp gas which significantly increases heat output.
