Slow day, So ill post my chassis makin walkthrough.
thegodofclod
Post by thegodofclod » Fri Aug 29, 2008 2:09 am
I decided, since I have these txt axles, an emaxx trans, custom Links, an extra ESC, a body, a mag meyhem and a little bit of free time, why not make a new crawler?
First thing to do when making the chassis was to design it and put it on paper. I had set the Links and axles up how I though they would work best and took rough measurements to get some base numbers to start with. After I had a basic design, my imagination took over.
After I had it on paper, I cut it out and folded the paper to form a belly.
I grabbed some scrap extra thin sheet metal to form the bends. You can use anything thats thin, I just happened to have a bunch of thin colored aluminum used for name engraving sitting around.
I taped the paper to the metal, and marked where the folds go. Then I removed the tape/paper and formed the sheet to where I wanted it. Then I retaped the paper back on and made sure that the aluminum is covering the holes used for suspension/links so I could use the sheet as a mock up template. I used cardboard for the two top side plates because it was easier.
After I had the holes drilled and the chassis formed, I mocked-up the suspension. This was invaluable when figuring out link positions and certain things such as pinion angle, axle turning, and binding, etc. I mounted a body on it to get an idea. I might lower the shell down a bit though, seems too high for me.
So far I already realized that the upper links being on the angle would bind the suspension up a ton and also give me terrible pinion angle and axle steer. I moved the link mounts up to the flat sides of the tub and the suspenision became 10x more efficient. I like the design now, but i will improve it with new holes and such when i get everything mocked into place. I will also probably make the whole set up adjustable, have the links set at the current wheelbase but have the ability to adjust a half inch or so in each direction. It would give me a +1"/0/-1" Wheelbase adjustment. Not bad.
When it comes to the final chassis material, I'm using aluminum. It's either go buy a sheet somewhere, or else find some scrap. As soon as I pick it up I will post more.
rcktpwrd
Re: Slow day, So ill post my chassis makin walkthrough.
Post by rcktpwrd » Fri Aug 29, 2008 4:06 pm
looks pretty cool 8) nice work so far.
I recently redid my crawler using Clod axles and TLT chassis plates :biggrin: seems to work decent... :wink:
thegodofclod
Post by thegodofclod » Fri Aug 29, 2008 4:18 pm
Lol my first clod crawler had 1/4 inch lexan side plates and was linked, it worked good till i kept destroying shock mounts and then sold off the clod axles for tlt-1 axles, which i then traded for complete txt axles.
