NEED ELECTRICAL HELP! DIY - 2.4Ghz Upgrade vintage Futaba TX
Luarana
Post by Luarana » Sun Jun 08, 2014 7:01 am
Hi All,
About to upgrade an Attack-SR to FrSky 2.4Ghz.
Just having a few issues because the RF components are part of the board instead of on a separate board.
Components:
Futaba Attack-SR FP-T2VR
FrSky DIY 2.4Ghz Module
http://www.hobbyking.com/hobbyking/stor ... odule.html
Challenges:
1. Isolate PPM Signal to Feed into 2.4Ghz Module.
2. Disable old RF Circuit *Apparently will blow circuitry due to excess power usage*
3. Find VCC
I've located a rough schematic of the Attack-SR 'seems fairly accurate'
This is the component side of my Board/
Image'
This is the rear side of the board.
As far as i can work out.
I need to cut off power to the Crystal Oscilator circuit, and the 2 RF modules components underneath the antenna.
