servo question
buckshotrc
servo question
Post by buckshotrc » Tue Oct 22, 2013 3:25 pm
i have tried to use the stock clodzilla 2 set up with the servos that were in it when i got it they are futaba s3305 - on 3s esc says bec is auto set at 5.8....do i need more torque ? even with alxe mounted dont seem to be strong enough....how much torque should i run in zh axle mountedilla 2 center 1 servo on both or how much if i have both axle mounted ?
my esc is 320amp 3s or 4s only
Re: servo question
Post by charliechristmas58 » Tue Oct 22, 2013 4:42 pm
How much torque does your servo have ?? you well need 200 oz of torque or more to move those tires. I have used CPE's servo on all my builds here is a link to his store. you cant go wrong using this servo and for thge price your getting a heck of a deal.http://www.crawfordperformanceengineeri ... ducts_id=2
Re: servo question
Post by vwjuice » Tue Oct 22, 2013 4:44 pm
I agree with Charlie. I have several of the CPE servos and they are great.
Re: servo question
Post by charliechristmas58 » Tue Oct 22, 2013 4:49 pm
I looked up the futaba s3305 and it only has 124 oz of torque at 6volts your going to need a better servo. like i said you need 200 oz of torque at the least. more is better.
buckshotrc
Re: servo question
Post by buckshotrc » Tue Oct 22, 2013 5:22 pm
is that 200 to run the stock zilla 2 1 servo for steering both end or 200 on each end front and rear ?
Re: servo question
Post by andymac0035 » Tue Oct 22, 2013 6:12 pm
S3305 is a good servo, I used one for a long time in my first super clod.
It has a short cord though and you'll need extensions to use in most likely.
I have since switched to the CPE servo's.
Re: servo question
Post by charliechristmas58 » Tue Oct 22, 2013 7:17 pm
200 on front and rear thats what i would do. im not sure if it would turn both front and rear but you can try if it does then great if not then you well need one on the front and rear.
Re: servo question
Post by andymac0035 » Tue Oct 22, 2013 7:41 pm
It will Charlie.
Remember all those vids of my original super clod with the white clod body and the with white trans-am body?
All of those were with a single futaba S3305 and stock steering.
It's not as good as the CPE servo, but it is a good servo, and it will do the job.
Re: servo question
Post by charliechristmas58 » Tue Oct 22, 2013 7:46 pm
But he said
buckshotrc wrote:i have tried to use the stock clodzilla 2 set up with the servos that were in it when i got it they are futaba s3305 - on 3s esc says bec is auto set at 5.8....do i need more torque ? even with alxe mounted dont seem to be strong enough....how much torque should i run in zh axle mountedilla 2 center 1 servo on both or how much if i have both axle mounted ?
that tells me that servo isnt doing the job
Re: servo question
Post by andymac0035 » Tue Oct 22, 2013 7:57 pm
Good point, might be a (linkage) binding issue too though.
NOUSEFORANAME
Re: servo question
Post by NOUSEFORANAME » Sun Oct 27, 2013 5:08 pm
I use Hitec HS-645MG 133oz torque, have always been good for me, but I don't use wideners which will put more leverage on the servo, and I run front steer only, axle mounted servo.
