Traxxas TQI 2.4 radio setup
Zac_F85
Post by Zac_F85 » Thu Sep 26, 2013 11:57 pm
I did a quick search and came up with nothing.. I need to reverse the direction of 1 servo on my clod for 4WS
I can't simply switch the connector around - it senses that and kills both Ch.1's all together..
HELP! I want to drive my clod before night fall!
EDIT - I have the intelligent radio that can use a Ipod or Iphone.. both of which I do not have..
Re: Traxxas TQI 2.4 radio setup
Post by SFC K » Fri Sep 27, 2013 12:01 am
I believe you have to use the program button on that radio to switch it. Look at the manuel. It should tell you how to switch it.
Post by SFC K » Fri Sep 27, 2013 12:05 am
Page 14 tells you how to program it...
http://traxxas.com/sites/default/files/ ... 120130.pdf
Zac_F85
Post by Zac_F85 » Fri Sep 27, 2013 12:10 am
SFC K wrote:I believe you have to use the program button on that radio to switch it. Look at the manuel. It should tell you how to switch it.
OK I finally found the manual on Traxxas.com!
Hopefully I can get this to work now!
Zac_F85
Post by Zac_F85 » Fri Sep 27, 2013 12:15 am
Well looks like you can only reverse the channels together so I'm F'ed it seems unless anyone has any ideas?
91lxcoupe
Post by 91lxcoupe » Fri Sep 27, 2013 12:21 am
i think your only option is a servo Y harness that will switch it automatically without the radio
Zac_F85
Post by Zac_F85 » Fri Sep 27, 2013 12:26 am
91lxcoupe wrote:i think your only option is a servo Y harness that will switch it automatically without the radio
hmm maybe.. now to find a cheap one haha
91lxcoupe
Post by 91lxcoupe » Fri Sep 27, 2013 12:27 am
they are typically on ebay cheap. andymac may have one he can sell you.
Post by andymac0035 » Fri Sep 27, 2013 1:22 am
Flip the servo arm upside down on the rear servo.
Zac_F85
Post by Zac_F85 » Fri Sep 27, 2013 1:23 am
looks like that is the only way.. which sucks!
Zac_F85
Post by Zac_F85 » Fri Sep 27, 2013 1:24 am
andymac0035 wrote:Flip the servo arm upside down on the rear servo.
I'm not sure the CPE link is long enough for that..
Post by andymac0035 » Fri Sep 27, 2013 1:30 am
Vertical servo mount?
If so....flip the whole servo.... it ought to be close.
Might have to un-thread the link-ends a little and add spacers (nuts/washers)
Y-harness does you no good unless it's one with a reverser built into it.
I don't hear good things about using those however.
And no, you can't reverse just 1 steering servo with that.
Some people have re-wired a servo though (but not me).
Zac_F85
Post by Zac_F85 » Sat Sep 28, 2013 2:47 am
I just swapped the servo saver position and it works.. this truck hauls! it's WAY to torquey though haha need to turn the sensitivity of the throttle down a bit so it doesn't strip the gears I'll post pics tomorrow if it's not raining!
Post by andymac0035 » Sat Sep 28, 2013 3:04 am
Cool! Glad you got it figured out! :thumbsup:
Zac_F85
Post by Zac_F85 » Sat Sep 28, 2013 3:08 am
kinda! still can't get the sensitivity on the throttle to soften up but oh well it's a blast.. don't handle to well and was only able to use 4 shocks instead of the 8 I wanted.. none the less it's fun just have to easy into it as it's a lot snappier than my old 3903 Emaxx.. I can't wait to get the body done!
