ecx1069
- Approved Member
ecx1069
Had anyone used or know if these would work on a clod?
http://www.ecxrc.com/Products/Default.a ... ID=ECX1069
Re: ecx1069
I wouldn't use it. That's not enough torque. You want at least 150oz. In.
- Approved Member
Re: ecx1069
Thanks for the advice
Re: ecx1069
Check out Cpe. Brett has a really good servo for $20. I have several of them.
- Approved Member
Re: ecx1069
i am going to be using a vertical servo mount so does this servo come with the right servo saver/arm i need?
http://www.crawfordperformanceengineeri ... ducts_id=2
- andymac0035
- Administrator
Re: ecx1069
It comes with an assortment of plastic servo horns. You will want to buy a proper heavy duty servo saver. CPE sell a blue one made by ofna, but I much prefer the kimbrough #124 model. CPE does not carry it though, so you'll have to hit up ebay or tower to get it. I like that one so much that's exactly what I do.
Oh and you'll need to order the little servo mount posts for that vertical mount.... I don't think they are included with it.
Stock clod mounts work to though, so I guess you don't have to.
- Approved Member
Re: ecx1069
i dont have a stock clod mount i have a vertical mount with hardware but im not sure what posts your talking about
- andymac0035
- Administrator
Re: ecx1069
The one's you use to bolt the steering servo down in the stock location.
They are what holds the servo to the mount.
- andymac0035
- Administrator
- Approved Member
- andymac0035
- Administrator
Re: ecx1069
^^^ Look one post above yours and you'll see a link to what you need to make that work.
- Approved Member
Re: ecx1069
totally didnt see that post i see what your sayin know
