Servo Issue
jdmerrill1240
Servo Issue
Post by jdmerrill1240 » Mon Mar 04, 2013 3:21 pm
Ok so I'm having an issue with the throttle servo on my Savage 21, as soon as I turn on the power to it the servo it opens the throttle about 3/4 of the way...if you turn the power back off it will go back to the idle position or if you turn on the radio and push the trigger to engage the brake it will also return to the idle position. Anyone else ever have this issue or have any idea what might be wrong? They are the stock HPI servos.
Re: Servo Issue
Post by andymac0035 » Mon Mar 04, 2013 4:34 pm
Sounds like it could possibly be a sub-trim issue?
Not really sure, hopefully someone will chime in with a better answer soon.
Also, moved to proper section to help get better responces. :)
slapshot1979
Re: Servo Issue
Post by slapshot1979 » Mon Mar 04, 2013 6:21 pm
Do you have any trim set to this servo thru your radio??
Is it set to zero?
If not remove servo linkage, turn on transmitte,r then truck as you normally would. it should stay at 0 . resinstall linkage and you should be ok.
jdmerrill1240
Re: Servo Issue
Post by jdmerrill1240 » Mon Mar 04, 2013 6:42 pm
slapshot1979 wrote:Do you have any trim set to this servo thru your radio??
Is it set to zero?
There is no trim set through the radio, Ill give what you said a try when I get home tonight. I was thinking about upgrading the steering servo and taking it to replace the throttle servo to see if that fixes the issue.
Re: Servo Issue
Post by SFC K » Mon Mar 04, 2013 8:04 pm
I would make sure the servo horn is centered on the servo first with the linkage removed. Basically power up the servo and center the trims on your radio and put the servo horn back on once it is cetered and set right with your radio is set right. Than attach your linkage and try it.
BTW, what radio are you using with this? If their is a throttle adjustment nob make sure it is centered as well.
slapshot1979
Re: Servo Issue
Post by slapshot1979 » Mon Mar 04, 2013 8:34 pm
Thats what I was tring to say Only ^^^HE ^^^ said it better.
jdmerrill1240
Re: Servo Issue
Post by jdmerrill1240 » Mon Mar 04, 2013 9:06 pm
SFC K wrote:I would make sure the servo horn is centered on the servo first with the linkage removed. Basically power up the servo and center the trims on your radio and put the servo horn back on once it is cetered and set right with your radio is set right. Than attach your linkage and try it.
I am using a 2.4 Traxxas TQ radio
Re: Servo Issue
Post by andymac0035 » Mon Mar 04, 2013 10:32 pm
jdmerrill1240 wrote:I am using a 2.4 Traxxas TQ radio
Go into your menu and reset all settings to defaults.
I've had to do that a few times in the past with mine.
