Flysky receiver problems
Post by vwjuice » Tue Jan 08, 2013 1:44 am
I have three Flysky receivers that have been sitting on the shelf and I went to use them today and all three of them have failed. Channel 1 is not working on all three and I tested two different tranmitters to see if it was a faulty transmitter. Has anyone else had any issues with this?
Re: Flysky receiver problems
Post by vwjuice » Thu Jan 10, 2013 3:28 am
Figured out the problem with my radio. The dual rate knob hassle a wire that somehow tore almost in half on both radios. I snipped the wire and cut it clean then resolve red it on and problem is fixed. Both radios now work just like they should.
Post by vwjuice » Thu Jan 10, 2013 3:33 am
Figured out the problem with my radio. The dual rate knob has a wire that somehow tore almost in half on both radios. I snipped the wire and cut it clean then resolder it on and problem is fixed. Both radios now work just like they should.
