Help Im a idiot!!!
ClodMonster
Re: Help Im a idiot!!!
Post by ClodMonster » Mon Jan 09, 2012 11:06 pm
Actaully you have the tq3 with the red toggle switch. You'll need to wire the servos together on a y harness on channel 1.
ClodMonster
Post by ClodMonster » Mon Jan 09, 2012 11:07 pm
1badclod85 wrote:no works still does the crab walk. I think I may have to relocate my rear servo maybe?
Flip your servo around, and recenter your servo arm. This should solve the crabing issue.
Post by cpe mt » Mon Jan 09, 2012 11:19 pm
You need to purchase the reversing Y harness, not a standard servo Y harness. You can also flip over the rear servo and reinstall the servo horn, which should also work. Good luck!
Post by TamiyaTony » Mon Jan 09, 2012 11:21 pm
That's an odd situation. Are you making sure that the rear servo is facing the opposite direction? Also, perhaps you have the servo horn on the wrong side? On top versus the bottom? I've never run this configuration, so I'm new at this too.
:roll:
Post by Justinswraps » Mon Jan 09, 2012 11:24 pm
cpe mt wrote:You need to purchase the reversing Y harness, not a standard servo Y harness. You can also flip over the rear servo and reinstall the servo horn, which should also work. Good luck!
Ahhhhhhhhh I c that makes a lot of sense life saver Brett! Thanks
And thanks to everyone else for helping sorry for the confusion :roll:
Post by Justinswraps » Mon Jan 09, 2012 11:25 pm
TamiyaTony wrote:That's an odd situation. Are you making sure that the rear servo is facing the opposite direction? Also, perhaps you have the servo horn on the wrong side? On top versus the bottom? I've never run this configuration, so I'm new at this too.
:roll:
Yeah it took me a minute but I saw that I have the front and rear servo in the same position lol.
todd ritchings
Post by todd ritchings » Mon Jan 09, 2012 11:28 pm
Post by Justinswraps » Mon Jan 09, 2012 11:32 pm
Thanks Todd very helpful!
ClodMonster
Post by ClodMonster » Mon Jan 09, 2012 11:32 pm
:roll:
You silly beaver!
Post by charliechristmas58 » Mon Jan 09, 2012 11:34 pm
I had to rewire my tq3 with a new switch so that i could control the back steeling the way i wanted it to work.
ClodMonster
Post by ClodMonster » Mon Jan 09, 2012 11:36 pm
charliechristmas58 wrote:I had to rewire my tq3 with a new switch so that i could control the back steeling the way i wanted it to work.
3 point toggle switch mod FTW! :D
Post by Justinswraps » Mon Jan 09, 2012 11:37 pm
well I got a 3 postion switch I just put on my tq3 so I could control the rear seperate but I wanted just for bashing I wanted the turning radius to be better without having to hit a switch everytime I turn.
ClodMonster
Post by ClodMonster » Mon Jan 09, 2012 11:42 pm
1badclod85 wrote:well I got a 3 postion switch I just put on my tq3 so I could control the rear seperate but I wanted just for bashing I wanted the turning radius to be better without having to hit a switch everytime I turn.
Flip it, y harness to channel one, and your golden dude!
gears
Post by gears » Sat Jul 20, 2013 10:08 pm
I saw this post and thought.... "hmm, I must have started this thread"
Just did the same thing with the stock bell cranks, forgot to reverse the rear top half.
So you've got is sorted then?
