how do i do dual servo steering cheap?
cher9498
Post by cher9498 » Tue Mar 29, 2005 12:00 am
any help with this would greatly be appreciated
i finally got a clod i've wanted one since i was ten
Suprachrgd82
Post by Suprachrgd82 » Tue Mar 29, 2005 6:27 pm
Cher, you looking to do 4 wheel steering? Also, just 4 wheel steering or crab walk it too?
If you want just the steering, it will cost you one extra servo and a splitter. There are 2 types of splitters: both servos go the same direction, and servos go opposite directions (has an internal POT with adjustement).
It shouldn't cost you more than $35 for everything.
cher9498
dual steering
Post by cher9498 » Tue Mar 29, 2005 10:42 pm
i want to do 4whell steer lik it is stock but with 2 servos
i have the servo and got a splitter from a revo but i do not know how to make or where to buy the servo mounts
Post by 132NHAF » Wed Mar 30, 2005 1:50 pm
Check out mudcow.com. He shows how to make some mounts and they are pretty straight forward. I made two recently and they work great.
Krod Clod
Post by Krod Clod » Wed Mar 30, 2005 5:02 pm
132NHAF wrote:Check out mudcow.com. He shows how to make some mounts and they are pretty straight forward. I made two recently and they work great.
would be great if JK's site was still up :wink:
:invisable:
black is back
cher9498
Post by cher9498 » Wed Mar 30, 2005 9:52 pm
thank you very much
Electrohacker
Post by Electrohacker » Wed Mar 30, 2005 11:02 pm
I do recomend upgradeing to a 3 or 4 channel radio down the road though... because 4 wheel steering at speed make you filp, but at slow makes you more manuverable.... ans crab steering is just plain fun
cher9498
Post by cher9498 » Tue Aug 23, 2005 9:58 pm
thanks guys for your help now iam looking at lifting my clod some
mods are addicting lol
oldShovelhead
Post by oldShovelhead » Wed Sep 21, 2005 8:54 pm
I'm looking to do the same thing on a Clod 1 and a `Zilla II - that link is dead - anyone have any pics of this DIY servo mount?
106pete
Post by 106pete » Tue Jan 10, 2006 3:36 pm
i was using dual servos, found 2 fatubas wud crab along but 1 fatuba and 1 hitec servo turned perfectly, they must have opposite directions to each other.
tweaked racing tube frame.
TTR front steering/ locked rear.
Novak Super Duty XR.
alloy rear gearset.
water tight electrics.
stock pinions and speed gems.
fillmbe
Re: how do i do dual servo steering cheap?
Post by fillmbe » Mon Apr 15, 2013 1:27 am
I run ESP's dual servo steering on my one truck, it mounts 1 servo on each axle. For just 4 wheel steer you just use a Y connector on the servo wires to crab walk you need a 3 channel radio and set it up with a channel for the front and one for the back. I ran a 3 channel for a while, I didnt like it. To much going on at the same time.
