Savage 25 pull start
Zep71
Post by Zep71 » Tue Aug 01, 2017 6:25 pm
i have been having troubles with the pull starter on my savage 25 first one was coated with old oil and really sticky. so i put a new one on it pulls fine for 5 to 10 pulls then the string pulls out any idea why ?
ratpower396
Re: Savage 25 pull start
Post by ratpower396 » Wed Aug 02, 2017 1:40 pm
Did you replace the one way bearing?
Zep71
Post by Zep71 » Wed Aug 02, 2017 2:42 pm
no it seems to work when i spin it by hand free 1 direction turns the crank in the other direction. i guess it could be a problem.any insight into this might help
thank you
ratpower396
Post by ratpower396 » Thu Aug 03, 2017 11:59 pm
if the string retracts but motor doesn't crank then it's the one way. temporarily you could spray the bearing with brake cleaner but you should still get a new one.
NorthernNightmare
Post by NorthernNightmare » Tue Aug 22, 2017 1:58 am
I just picked up a almost brand new savage x for crazy cheap 150 us with k 4.6 jumbo swamp kong tires worth about $100b and bunch of other upgrades also at least $100, Dont worry I not using the swamp kongs for the savage but another project
I gess my question is, with my the roto start that is broken been using a drill but the backing plate is also loose and about to fal;l apart.
I ordered a few different pull starts for the reason I not sure witch on is right for my engine, one purple say big block on it and the other is a kit and black says only hpi kit....
I hope I can just get a new owb at my LHS
Post by 132NHAF » Wed Aug 23, 2017 2:17 pm
For pull starter issues, I have also gone through a couple of one-way bearings. I finally found out that super cleaning the bearing I was actually ruining it. My thought was "why would I put oil on it, it will slip" , not true. The one-way needs a small amount of oil to keep it from burning up when the engine is running. Once I realized that a gentle cleaning (simple green vs. carb cleaner) and a couple of drops of oil was the ticket I stopped ruining bearings.
And yes, with the starter off, it will feel like the bearing is fine but you have to think about how much torque you are applying when yanking on that cord.
ratpower396
Post by ratpower396 » Thu Aug 24, 2017 7:30 pm
Go on eBay and look for a k4.6 pull start they are about $20
NorthernNightmare
Post by NorthernNightmare » Sun Aug 27, 2017 4:13 am
Thanks man just got a new O W B, and my pulls should be in any day :thumbsup:
ratpower396
Post by ratpower396 » Mon Aug 28, 2017 12:57 am
good luck. the savage motors are great motors. I have one in a big block tmaxx conversion that i set up for onroad fun that runs great.feed it well and it will run.
NorthernNightmare
Post by NorthernNightmare » Mon Sep 04, 2017 10:53 pm
Damb I just got my 2x pull start, and the o.w.b I bought is to large.
It fits on the engine, but the hex is 12mm I belive is about 2mm too big, both pull start asembleys are the same
Where can I get more parts for this Savage, I bought just about all my available parts local, and lots off e-bay.
But there sill lots to be put in my parts collection, like the rear engine plate, and diff sets....
ratpower396
Post by ratpower396 » Wed Sep 06, 2017 11:34 am
Look for a good parts truck
ratpower396
Post by ratpower396 » Wed Sep 06, 2017 11:35 am
Most parts are interchangeable with the new savage
NorthernNightmare
Post by NorthernNightmare » Sat Sep 09, 2017 7:32 am
Yup I got bit by the savage bug, unfortantly at the wrong time I hope hpi gets back on track soon.
As far as parts go i got a mostly everything I need So thanks for your help so far.
