vx .16 stalls
sunseri4819
vx .16 stalls
Post by sunseri4819 » Mon Aug 05, 2013 11:39 am
My buggy wont idle unless the tank is completly full. Afyer i run for a couple mintues it stalls out almost at every time i break. Any help
Re: vx .16 stalls
Post by SFC K » Tue Aug 06, 2013 12:50 am
Need more info or a picture of your set-up? Sounds like you need an adjustment on the carb or an issue with one of the fuel lines...
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 1:54 am
Its a brand new hyper speed 1/10 buggy with the stock carb settings. Itll run great for the first couple mintues then it wont idle for long at all and stalls if i dont gas while applying brakes
Re: vx .16 stalls
Post by SFC K » Tue Aug 06, 2013 2:11 am
When you look down into the carburetor with the breaks applied is the opening closed or open? You may need to adjust your low speed needle. It sounds like it is starving for air. Sometimes from the factory the settings can be off. Check your manual and you may have to reset them.
Temperature and weather play a big part in tuning nitro engines so you may have to tune it often depending on where you live.
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 2:19 am
Its just about hot year round here in florida
Re: vx .16 stalls
Post by SFC K » Tue Aug 06, 2013 2:21 am
sunseri4819 wrote:Its just about hot year round here in florida
But humidity plays into it too. Check the carb and if you can post a picture that would help. It sounds like you need to adjust it on the low speed needle side.
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 2:29 am
Ill take a picture tomorrow. Its gettin late. :sleepy: :sheepish: :sheepish:
Re: vx .16 stalls
Post by charliechristmas58 » Tue Aug 06, 2013 3:20 am
I have that same car.
Re: vx .16 stalls
Post by charliechristmas58 » Tue Aug 06, 2013 3:22 am
Oh and mine was doing the same thing. look at the tube going to the muffler. mine had a hole in it and i replaced it and it works fine now.If thats not it then look at the carb or glow plug. both of those have happned to me also.
Re: vx .16 stalls
Post by 132NHAF » Tue Aug 06, 2013 3:26 pm
What Charlie said makes sense. Make sure the pressure tube from the exhaust to the tank is clear, free of holes, and fits snug (preferably with a fitting) into the exhaust. Did you replace the glow plug after break-in?
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 5:17 pm
Yes but have not ran it yet
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 7:23 pm
With full brakes the hole almost gone. I can barely see it
Re: vx .16 stalls
Post by charliechristmas58 » Tue Aug 06, 2013 11:53 pm
You need to adj your carb then just a little not a lot 1/4 turn should do it
sunseri4819
Re: vx .16 stalls
Post by sunseri4819 » Tue Aug 06, 2013 11:56 pm
In which direction and what needle
Re: vx .16 stalls
Post by SFC K » Wed Aug 07, 2013 12:02 am
Your manual should tell you which way turn it if CC does not know and it should be the low speed needle. Also if you set the car on a box so the wheels can spin freely and fire it up you can adjust it that way too so you know it is right. Also it is best to do it when it is warmed up a bit. You just want to make sure the motor does not get loaded up and hyper lock or flood it. RPMs are your friend with nitro motors to keep the cylinder clear of unburned fuel.
