I got this today
I got this today
Post by charliechristmas58 » Mon Nov 19, 2012 11:27 pm
I got this nitro car today does anybody know anything about it ? and is it any good. just need someway to start it and a new recever. it has Team Associated on the body and PRO on the motor
nitro car 1 (Medium).JPG (61.69 KiB) Viewed 2641 times
nitro car 2 (Medium).JPG (70.4 KiB) Viewed 2641 times
nitro car 3 (Medium).JPG (62.15 KiB) Viewed 2641 times
Re: I got this today
Post by Justinswraps » Tue Nov 20, 2012 1:07 am
Thats a pretty good buggy you got your hands on there CC! Alot of guys take them and put a brushless conversion in them. If you like Nitro then I would leave it alone and bash it :twisted:
I cant tell but below the header is there a spot for a roto start? I personally would get a bump box
Post by charliechristmas58 » Tue Nov 20, 2012 1:22 am
It came with a bump box well thats what it said on the box. it takes 2 batterys they came with it. im new at this sort of thing the wire on the recever is cut so i need to get one and im having trouble getting the box to work. it spinns but when i press down on the car to start it the wheel stops moving or just spins on the starting wheel on the bottom . why cant it have a pullstarter
Post by Justinswraps » Tue Nov 20, 2012 2:44 am
does the fly wheel on the car sit low enough for the bump box? As for a pull start the motor probably has a back plate on it. Post a pic of the back of the motor where the header is. If it has a spot for a rotor start that would be your second best bet if bump box isnt working on the chassis.
Bump boxes can be tricky at times and the car has to be in the sweet spot.
Post by charliechristmas58 » Tue Nov 20, 2012 3:10 am
Yep the flywheel touches the wheel but its like there isnt enuff power to turn the motor im useing 3000 mah batterys. if i cant get it to work tomorrow im taking it to the lhs and see if they can do it. i dont see aspot for a roto start. but then again im not sure what im looking for .
Post by Justinswraps » Tue Nov 20, 2012 3:20 am
Yeah you need a much bigger battery.
This is the rotor start back plate. I think thats what on yours now because you have a RTR edition.
http://www.ebay.com/itm/Team-Associated ... 51a3004e2e
You can get these two parts and put a pull start on it.
http://www.ebay.com/itm/Team-Associated ... 5898833829
http://www.ebay.com/itm/Team-Associated ... 4d062b234d
Post by charliechristmas58 » Tue Nov 20, 2012 3:40 am
Is this what your talking about on the motor for the rotor start . its on the end of the motor
nitro car 4 (Medium).JPG (52.17 KiB) Viewed 2630 times
Post by Justinswraps » Tue Nov 20, 2012 3:58 am
yes Sir that'd be it!
Post by charliechristmas58 » Tue Nov 20, 2012 4:11 am
does this only turn one way ?
Post by Justinswraps » Tue Nov 20, 2012 1:04 pm
Yeah it will only turn to the left or right, I cant remember off the top of my head which way. One of the ways it should just spin and not turn over the motor and the other way the one way bearing will catch on the crank and turn the motor over
Post by charliechristmas58 » Tue Nov 20, 2012 6:06 pm
so would a drill do the samething or well it not turn fast ehough
Kingclod27
Post by Kingclod27 » Tue Nov 20, 2012 6:38 pm
I think some people do use a drive on their rotostart....Cool Buggy, Hope you get it up and running..Im loving mine so far (build process)..its a change of pace from the MTs and stuff
SPEED.......I..AM..SPEED
Post by Justinswraps » Tue Nov 20, 2012 9:15 pm
I used a drill on all of my Nitro's I had that were roto start, just for the fact a drill last longer than a 7.2v battery. If you have the drive rod for the roto start then you sould be golden or anything thing else that fits it :)
Post by Justinswraps » Thu Dec 06, 2012 7:15 pm
did you ever get this going CC?
Post by SFC K » Fri Dec 07, 2012 1:56 am
Wow! I totally missed this! When did CC get into Nitro? Yeah bud, did you get it going? Drill is the only way to start these.
I actually converted my RS4 over to Tiger drive as well. Just make sure you go the right way. You don't want to ruin the one way bearing.
