Ouch!
fatboyslim
Post by fatboyslim » Sun May 15, 2005 11:42 am
I use one of these...
http://www2.towerhobbies.com/cgi-bin/wt ... LXFRP3&P=7
nice and easy and NO burns!!
RcK cRwLr
Post by RcK cRwLr » Sat Jul 02, 2005 8:14 pm
Fly Wheel best for your engine
MIke
http://www.GSRCRC.com
r(k (rw1r
Post by Halgar » Sat Jul 02, 2005 8:39 pm
RcK cRwLr wrote:Fly Wheel best for your engine
That's fine if you have a buggy or stadium truck and the flywheel sticks down below the chassis. In monster trucks, the flywheel isn't as accessible, so the easiest means of shutting down the engine is either to pinch the fuel tube or choke the exhaust. IMO choking the exhaust is the better of the two since it doesn't lean out the engine.
TIER
Post by TIER » Sat Jul 02, 2005 11:31 pm
choking the exhaust isnt exactly the best for your motor either.. it basically floods the motor and stalls it, loading up the crank case one way bearing in the back with loads of fuel and could lead to premature failure or slippage of oyuer one way. it also leads to harder restarts from the motor being flooded at shutoff, this also adds stress on the internals at start up.
best way to shut it off is the fuel line pinch.. and if its not too dirty to plug the carb up but thats hard to do most of the time without risking dropping dirt particles in.
Maybe im crazy
Maybe your crazy
Maybe we're crazy
Probably
Post by Halgar » Sun Jul 03, 2005 2:48 am
TIER wrote:choking the exhaust isnt exactly the best for your motor either.
Everybody's a critic... :roll: LOL :wink: :lol:
Does the engine really have enough time to flood before the backpressure builds up too much for it to draw a charge in since it can't push out the exhaust? IMO, either method will work without detriment to the engine.
TIER
Post by TIER » Sun Jul 03, 2005 3:54 am
it cant push exhasust out the stinger.. so it pushes it all directly into the preasure line forcing fuel from the tank into the carb :wink: its not gonna kill your motor its just not as healthy for it as other methods...
Maybe im crazy
Maybe your crazy
Maybe we're crazy
Probably
Post by Halgar » Sun Jul 03, 2005 5:39 am
Well, I always disconnect the pressure line first!
:P :P :P :wink: :wink: :wink: :wink: :lol: :lol: :lol: :lol: :lol:
