using a tekin rs gen 2 in a clod
3sgte
Post by 3sgte » Sun Oct 02, 2016 4:28 pm
hey guys I posted this in the clod forum and i think it should have been posted here. can I run both clodbuster stock motors on a tekin rs gen2 esc in brushed mode? I have one laying around and figured I could try using it for now. I will also be running a 2s lipo.
thanks
Re: using a tekin rs gen 2 in a clod
Post by andymac0035 » Mon Oct 03, 2016 3:54 am
Assuming it can deal with the load (and I'm betting it can) then yes you can do that. You just need to make some y-harnesses for the motor leads.
All my clods are set up like this. You could likely use a 3S battery (that's what I use). I'm running an old mamba max and an old VXL esc in my brushed clods.
3sgte
Post by 3sgte » Mon Oct 03, 2016 10:08 am
ok tanks for the reply. Ill give it a try.
