Using 2 reverse rotation motors
CLODZ_72_2003
Post by CLODZ_72_2003 » Sat Dec 20, 2014 6:08 pm
Just picked these up off eBay and was wondering if there are any dis advantages of running two of the same reverse rotation motors
Alfy
You crawl with 4, But I drive with 18 :wink:
Thunder VP
Re: Using 2 reverse rotation motors
Post by Thunder VP » Mon Dec 22, 2014 6:57 am
If you are using them in a Clod, using 2 reverse timed motors, the front motor will be running slower than the rear causing the truck to push a bit.
You could gear up the front to get the speed to match better but its not the best thing to do to run negative timing for long periods of time.
