Power?
ramflames
Power?
Post by ramflames » Thu Nov 06, 2014 2:59 am
My Clod has more power and torque in reverse than in forward. I'm running the stock silver can motors. A Traxxas Xl-5 ESC and a 3S Lipo. I know the ESC is only rated for 2S, but I've run it many times on 3S without letting the smoke out. I have the motors wired in parallel. i have swapped motor leads around every which way possible. I have played with the radio settings. I have gone though the ESC set up procedure out lined by Traxxas. I'm stumped. It will do wheelies in reverse but not in forward. I want to replace the motors soon with traxxas E-Revo motors, but I'd like to figure out this problem before I do anything else. Please and thank you for any help that is provided.
ramflames
Re: Power?
Post by ramflames » Sat Nov 08, 2014 9:22 pm
Anyone? :(
Re: Power?
Post by SFC K » Sun Nov 09, 2014 12:14 am
Sorry bud, I have not tried that ESC combo yet. I only use the EVX ESCs. Have you tried swapping the motors from front to back and is the rear motor in reverse rotation, i.e. switch the motor leads?
Re: Power?
Post by Sixtys Guy » Sun Nov 09, 2014 1:21 am
Swap the motor leads around and then switch channel 2 on the TX to reverse....
ramflames
Re: Power?
Post by ramflames » Wed Nov 12, 2014 12:50 am
Thanks guys, I'll give it a try.
Re: Power?
Post by 132NHAF » Wed Nov 12, 2014 4:02 pm
Turn your body around...problem solved. #-o
ramflames
Re: Power?
Post by ramflames » Mon Jan 12, 2015 3:17 pm
Sixtys Guy wrote:Swap the motor leads around and then switch channel 2 on the TX to reverse....
This did the trick. Thank you
JHeitt142
Re: Power?
Post by JHeitt142 » Mon Jan 12, 2015 3:29 pm
132NHAF wrote:Turn your body around...problem solved. #-o
now theres an idea!
ramflames
Re: Power?
Post by ramflames » Mon Jan 12, 2015 4:05 pm
now theres an idea!
I thought about it, but then I remember I took out the rear steering. Ha Ha, just kidding.
Re: Power?
Post by Sixtys Guy » Mon Jan 12, 2015 8:48 pm
:thumbsup:
