EVX-2
DirtyJ
EVX-2
Post by DirtyJ » Sun Aug 04, 2013 11:20 pm
how dose the lvd work in the evx-2 dose it shut the truck down or is there a alarm or dose the light turn red just what happens when the voltage in a lipo gets low ?
Re: EVX-2
Post by andymac0035 » Sun Aug 04, 2013 11:24 pm
It shuts the truck down.
You must use a pair of 2S lipo's for the LVD to work right though.
It's (the LVD) not programable for different voltages.
You can run different voltages with it turned off though.
*EDIT* 11/28/13
The EVX-2's LVD does indeed work with different voltages, see page two of this thread for updates.
ironcorn
Re: EVX-2
Post by ironcorn » Fri Aug 09, 2013 8:06 pm
Mine appears to work correctly with both a single and dual 2S Lipo, I thought I read somewhere that is doesn't work right with 3S and 5S?
Re: EVX-2
Post by andymac0035 » Fri Aug 09, 2013 8:09 pm
That's what I kept being told by those that had one.
So, your able to use a single 2S and 3S lipo and still have low voltage detection function?
I may have to give this a try with mine then.
ironcorn
Re: EVX-2
Post by ironcorn » Fri Aug 09, 2013 8:17 pm
Mine works correctly when using a single 2S (with the other input jumped across) and when running dual 2S batteries for 4S total. When LVD hits it reduces power to 50% or something like that, but it's immediately noticeable. I've run both a single 3S and a 2S/3S combo for 5S total, but have never run them to the point that LVD kicked in, mostly because I though I read somewhere that the detection only worked on either 2S or 4S. I don't have any sacrificial batteries so I didn't want to test it with 3S or 5S.
Re: EVX-2
Post by andymac0035 » Fri Aug 09, 2013 8:20 pm
Interesting, well I have a low voltage alarm, so I'll bee checking the 3S function out when I get the chance. That way if it doesn't work....I'll know it because my alarm is going off.....instead of my lipo going ... :explosion:
Re: EVX-2
Post by andymac0035 » Fri Aug 09, 2013 8:21 pm
I do seem to recal reading somewere that a guy tried 3S and LVD kicked in right away because it was looking for 4S voltage....and finding 3S voltage.
DirtyJ
Re: EVX-2
Post by DirtyJ » Sat Aug 10, 2013 6:10 pm
ok how do I jump it or how do I install a lvd alarm my son is going to be driving this truck and I may not be around all the time so a loud alarm would be great thanks for the help.
Re: EVX-2
Post by andymac0035 » Sat Aug 10, 2013 11:17 pm
The alarm plugs into the balance port of the battery.
DirtyJ
Re: EVX-2
Post by DirtyJ » Sun Aug 11, 2013 2:44 am
where do I get it
Re: EVX-2
Post by andymac0035 » Sun Aug 11, 2013 2:59 am
I got mine from ebay. There's lots to choose from. You don't have to get the same model I did.
http://www.ebay.com/itm/Lipo-Battery-Vo ... 43be0c5a76
Re: EVX-2
Post by charliechristmas58 » Sun Aug 11, 2013 3:29 am
Get 2
DirtyJ
Re: EVX-2
Post by DirtyJ » Sun Aug 11, 2013 4:39 pm
ty for the help
Zac_F85
Re: EVX-2
Post by Zac_F85 » Wed Sep 11, 2013 1:03 am
to turn the LVD off on a EVX-2 you press and hold the program button and watch it flash so many times.. all the info is on traxxas.com on how to program it
I do know this - you can run lipo's in NiMH mode and you can run NiMH's in lipo mode
lipo mode (LVD) the LED is green
NiMH mode the LED is red
when the LVD is activated the truck will slow to almost a crawl, steering will be very slow.. it will be a sudden loss of power unlike a NiMH battery that gradually goes dead
If the LED on the ESC is green just let him run it - it should be fine.. no need for an alarm with a EVX-2 IMO
Re: EVX-2
Post by andymac0035 » Wed Sep 11, 2013 1:20 am
Zac_F85 wrote:to turn the LVD off on a EVX-2 you press and hold the program button and watch it flash so many times.. all the info is on traxxas.com on how to program it
Not exactly,
Pressing and holding the button with the esc off, brings you into programming mode.
This can be for calibration, or mode running mode set-up (standard/race/training)
This is were the flashing lights come into play.
Pressing the button with the esc on, and holding it for about 10 seconds will cause the light to change color AND more importantly you will hear a tone.
