6x6x6 Clod build
Re: 6x6x6 Clod build
Post by SFC K » Sat Sep 27, 2014 4:05 pm
That worked perfect! Do you think it will be strong enough to move with a load?
rknaub
Post by rknaub » Sat Sep 27, 2014 4:23 pm
I made a few adjustments last night so it's a bit more reliable. It had no problems pushing and pulling my clod crawler back and forth. And unfortunately something happened to the HPI ESC and reverse is now barely functional. It stutters bad and then quits. Any attempt at re calibrating throttle on the ESC is not working. I'm now in the market for a really cheap ESC, but unfortunately completely out of funds for a bit.
If anything fails, it will be the little part I made that threads on the all thread. It is aluminum tapped to 8-32. If anything the threads on it will strip, and I will replace with a steel version, possibly a bit thicker so I can have deeper threads. It's really just an experiment right now to see if I could make it work, and now that it does - I will slowly start working in perfecting it.
Post by Sixtys Guy » Sat Sep 27, 2014 9:05 pm
Hobbyking have a good little brushed esc for $10 if that helps.
rknaub
Post by rknaub » Sat Sep 27, 2014 10:58 pm
Sixtys Guy wrote:Hobbyking have a good little brushed esc for $10 if that helps.
Thanks I'll check it out!
