SFC K's Puller
Re: SFC K's Puller
Post by andymac0035 » Thu Nov 28, 2013 12:24 am
SFC K wrote:Ok experts, any ideas on which way I should go to accomplish a full pull? Pinion change up or down? I already know I need to adjust the hitch height. I think I have the weight set to where it needs to be.
Put a mamba monster in that thing! :explosion:
Seriously, if you are allowed to, you could adjust your speed just by adding or removing cells....... :idea:
Probably not viable......... but hey.... you asked. :mrgreen:
Re: SFC K's Puller
Post by SFC K » Thu Nov 28, 2013 12:46 am
2S is the max...I looked for motor limit and it does not really specify...I'm thinking no but I will have to ask the club, plus I really do not want to buy another Brushless system just for this. I need to work with what I got.
Re: SFC K's Puller
Post by SFC K » Sun Dec 01, 2013 3:42 am
Wish me luck tomorrow! I made some adjustments and fixed my current motor mount so now I can switch gears easily without having to loosen a bunch of other nuts and bolts. I hope I went the right way with my adjustments... :)
Re: SFC K's Puller
Post by Diamond Dave » Sun Dec 01, 2013 3:57 am
Good luck to ya! I want to see the results. The rush of pulling the trigger and seeing what happens is awesome. Go man GO!!
