SFC K's Puller
Re: SFC K's Puller
Post by SFC K » Sun Oct 06, 2013 1:32 am
Budhatrain wrote:
Brad from TTR is a wizard at pulling, be sure to ask him mucho questions.
I was hoping to get his attention too. :wink: I posted my build over on RCMT as well... :wink:
That does help Mike...It is hard to find pictures of the bodies off on puller trucks...Thanks!!!!
Re: SFC K's Puller
Post by Budhatrain » Sun Oct 06, 2013 1:37 am
The guys at the track should be really cool and help you out a lot. I know thats how they are around here. Some of the guys don't want to share all their secrets but I haven't ran into any like that. That's probably why you haven't seen to many body off shots though.
Personally i dont care so I will build one too! These look easy to fabricate from raw materials we can get locally :). I will share with you what I find out. I feel we should readily share the information to get more people involved!
Re: SFC K's Puller
Post by SFC K » Sun Oct 06, 2013 1:40 am
Budhatrain wrote:The guys at the track should be really cool and help you out a lot. I know thats how they are around here. Some of the guys don't want to share all their secrets but I haven't ran into any like that. That's probably why you haven't seen to many body off shots though.
Totally agree on that Mike! I will be taking notes when I go to the meet. Some of the guy's are from the Crawler scene here as well. This is more so to have something to do in the winter months for some... :wink: :mrgreen:
Re: SFC K's Puller
Post by SFC K » Sun Oct 06, 2013 8:22 pm
Added front bumper so I can add suit case weights to it...Now where are those gears.... :roll:
Re: SFC K's Puller
Post by andymac0035 » Mon Oct 07, 2013 2:30 am
Man this just keeps getting better! Nice work! :thumbsup:
Thunder VP
Re: SFC K's Puller
Post by Thunder VP » Tue Oct 08, 2013 12:35 am
I've been watching. Looks like its heading in the right direction.
What's the motor and battery limit for the 7# class?
I run NR/CTPA dirt 10# ProMod.
I did all carpet pulling years ago so I do know that well also.
100:1 seems really high to me even for carpet. 50-60:1 sounds more reasonable, but if the guys you will run with are up there, I guess take their word for it.
Here's the ProMod chassis I build:
You can see a loose gearbox beginings in the background.
4wd:
If you would like to see other body off pics, I'm sure I can help out.
I will be up in MN for a few days at the end of the month. Too bad it was not a week earlier, I could have made the practice.
Re: SFC K's Puller
Post by SFC K » Tue Oct 08, 2013 12:43 am
Thanks a ton Brad! That does help! I wish you were going to be here for it too. They are also having a swap meet that day as well so it is going to be a double hoot!
That Promod chassis looks really tight! 8)
I also have it all together now and ran it across the carpet. I think you are right on the 100:1 being to high. It seems to be slower than what I have seen on Youtube...PaulS is the one that gave me this advice. You might know him as he is a member over on RCMT as well. I will post some pictures tonight. :wink:
Re: SFC K's Puller
Post by SFC K » Tue Oct 08, 2013 1:25 am
Updates:
I am thinking the 27T motor is too slow. I think I am going to put the Duratrax back in and see if I can get a little bit more wheel speed. Thoughts?
Re: SFC K's Puller
Post by SFC K » Tue Oct 08, 2013 1:45 am
I recalculated my gear ratio and it is 88:1 so maybe it will be fine? I am going to leave it as is until the practice round on the 20th and adjust then....
Thunder VP
Re: SFC K's Puller
Post by Thunder VP » Tue Oct 08, 2013 1:51 am
27T is not what you want. I would recommend a 10-12T if you have one and want to stay brushed.
On dirt we run around 20-35:1 with a 3S and up to 6900kv motors so they are moving.
If I remember right our carpet ProMods ran 40-60:1 even before brushless was allowed. It did make the motors run hot and required frequent brush changes.
Brushless is a whole new game now.
Do they have a motor & or cell limit for the 5&7# classes?
I'll be at the NR/CTPA Worlds this weekend, are any of the MN guys going this year? I met a few of them when they came in years past.
Re: SFC K's Puller
Post by SFC K » Tue Oct 08, 2013 2:00 am
Ok, I will change that out right away. I was wondering what size motor was key to starting out.
Max voltage for Brushed motor is 8.4. I am using 2s pack so I should be good. They said the follow the 5-7 lb rules...Other then they do allow the rc4wd pulling tires.
I'm not sure if any of them are going to the worlds or not. I have not met most of the club yet.
Re: SFC K's Puller
Post by SFC K » Tue Oct 08, 2013 8:22 pm
If I go 12T or less would a Traxxas 12T Titan be a good choice? Just curious what type of brushed motors work the best, closed end bell or rebuildable...
Re: SFC K's Puller
Post by SFC K » Tue Oct 15, 2013 2:01 am
Updates, All done except for the rear body mount...I went with the 12T Titan motor and the speed seems right. I am excited to go practice with this on Sunday! :)
Some more pictures...
Re: SFC K's Puller
Post by charliechristmas58 » Tue Oct 15, 2013 2:32 am
Looking good. now get it painted well ya
Re: SFC K's Puller
Post by Budhatrain » Tue Oct 15, 2013 2:34 am
I just picked up a chassis this weekend at the worlds. Already have it at a machine shop for some weights to be added.
keep it up, you ARE my inspiration!!!
