Slipper clutch question
Awesome Kong84
Post by Awesome Kong84 » Wed Nov 08, 2017 2:48 am
Can any slipper clutch kit work with an AX10 transmission? I have the one that comes with the Hot Racing trans however one of the screw holes stripped out. I am trying to find a replacement but my LHS doesn't have any. The ones I find online the shipping cost is too high. Would a Traxxas Jato slipper kit work? Thoughts?
Re: Slipper clutch question
Post by andymac0035 » Wed Nov 08, 2017 11:55 pm
I have put a traxxass clutch plate on a axial slipper plate before and it worked fine. I did have to use a short spring though.
Awesome Kong84
Post by Awesome Kong84 » Tue Nov 14, 2017 7:15 pm
Thanks for the tip. The LHS always has Traxxas stuff. Can't hardly fine Axial stuff in stock. Do you happen to recall the spring size you used?
Post by andymac0035 » Wed Nov 15, 2017 3:13 am
If I remember correctly, I took one of those springs used on the stock clod axle mounted servo saver, and cut it down (I think in half).
