Savox Servos
DirtyChevy45
Savox Servos
Post by DirtyChevy45 » Tue Jul 25, 2017 3:20 pm
getting close to the next step in the project and lookin into electronics.... there are alot of different ones out there but i think id like to go with these guys for the servos. look like good high quality stuff... but which ones have you guys had the best luck out of and do you need to run a BEC with it? thanks in advance!
Mike
87lc2
Re: Savox Servos
Post by 87lc2 » Sat Jul 29, 2017 3:46 am
I only run Savox on on truck as they are expensive and I like to play in mud too much, but I believe it is the 1258. I run it on my Barbarian chassis truck with AR60s and for 166 oz/in it does great, truck is 2WS also. Best part about the servo is the speed, its very quick.
I don't run a BEC with it, but not sure about that if you are running two with 4WS.
Re: Savox Servos
Post by Sixtys Guy » Sat Jul 29, 2017 9:16 am
I run a 1258 in my 2wd racing buggy. I think a lot of MT guys run the 1256 which is the high torque version. There is also the 0231 which is waterproof and quite a bit cheaper than most Savox servos. I haven't heard any feedback on these, but being waterproof and relatively high torque I would assume they would work fine.
DirtyChevy45
Re: Savox Servos
Post by DirtyChevy45 » Tue Aug 01, 2017 1:53 pm
awesome thanks for the input ill check them out!
Re: Savox Servos
Post by Sixtys Guy » Tue Aug 01, 2017 9:19 pm
Found this one searching Amain the other day; https://www.amainhobbies.com/savox-sa12 ... sg/p234359
444 ounch/inch! I reckon that would need an external BEC.
