Soze's MST CFX-W Build
soze
Re: Soze's MST CFX-W Build
Post by soze » Fri Jun 30, 2017 11:02 pm
While I'm waiting for my hilux shapeways parts, I'm trying to decide which tires to go with.
Pro-line BFG Krawlers
Pro-line Hyrax
JConcepts Ruptures
soze
Post by soze » Tue Jul 04, 2017 10:14 pm
Had time to do a few things last night.
Got started with the Boom Racing 313mm Extension links.
Boom Racing Servo Horn
6mm thick Hexes
ratpower396
Post by ratpower396 » Wed Jul 05, 2017 11:38 am
6mm hexes???
soze
Post by soze » Wed Jul 05, 2017 6:49 pm
6mm hexes???
12mm size, 6mm thick.
ratpower396
Post by ratpower396 » Thu Jul 06, 2017 3:34 pm
im partial to the krawlers
soze
Post by soze » Sat Jul 08, 2017 5:14 pm
Encountered an issue with the Boom Racing steering links...
The links hit the Axle cover at both ends of the steering angle. This restricts the steering angle a few degrees less than the stock links. It's more an issue with the rod-ends used. They aren't offset enough. I'll need to look for some M4 sized rod-ends with more off-set.
Comparing the Boom Racing steering link with stock
Anyway... the rear links installed.
soze
Post by soze » Sat Jul 08, 2017 11:49 pm
Got my Knights Customs roll bar in, but I'm not sure how I'll mount it yet. I'll need to strengthen the holes to not have the screws grind away at it. Maybe fill the holes with something or find a way to glue something to use body pins.
Also started prep work on the bed so that I can spray it with plasti dip as a bedliner.
Also mounted my alloy beadlock wheels and Pro-Line Racing Hyrax 1.9 G8 Rock Terrain Truck Tires onto the truck.
soze
Post by soze » Sun Jul 09, 2017 6:36 am
This is what happens when you wait too long for some parts..... you end up ordering more parts.
Bought the MST Steel driveshaft kits and just got them in.
MST CFX-W Steel drive shaft [210571]
MST CFX-W Steel drive shaft set 99-119mm [210569] x 2
Post by Sixtys Guy » Sun Jul 09, 2017 8:30 am
Mods look great. Really like the look of this. :thumbsup:
soze
Post by soze » Mon Jul 10, 2017 6:16 am
Got the bed painted today. Progress being made! Just need those shapeways parts to get here ASAP.
Post by andymac0035 » Wed Jul 12, 2017 3:59 am
That came out really good! Can't wait to see some pics of it in action. :popcorn:
soze
Post by soze » Wed Jul 12, 2017 4:59 am
Not done yet! More parts came in today!
soze
Post by soze » Wed Jul 12, 2017 5:48 am
Those parts finally came in...
soze
Post by soze » Sat Jul 29, 2017 3:53 am
So... right now this build is being held up by getting the finish of these 3D printed parts right. I've wetsanded and clear coated, but I can't seem to get the cloudiness out of the clear parts. Anyone got any suggestions?
Thunder VP
Post by Thunder VP » Sat Jul 29, 2017 2:54 pm
