Shaft drive Clod?
Shaft drive Clod?
Post by SFC K » Wed Nov 02, 2016 12:57 am
:mrgreen: Yup, that is right folks! I am converting a Clod tub chassis into a center mounted trans and with G-Made R1 axles. I have modified the tub already to fit the G-Made Transmission. Axles will be 4 linked using a CPE Aluminum Chassis brace drilled to hold the transmission.
Re: Shaft drive Clod?
Post by Sixtys Guy » Wed Nov 02, 2016 1:16 am
Awesome! Different, I like it! I have always been intrigued by those axles. Keeping a Clod body?
Post by SFC K » Wed Nov 02, 2016 1:33 am
Sixtys Guy wrote:Awesome! Different, I like it! I have always been intrigued by those axles. Keeping a Clod body?
They are different. and I like how they have the portals built into them creating more clearance. I thought abut doing a Clod body, but these axles are so wide, it might look funny even with fender flares. I need to find someone with a Bullhead body that can measure the width from fender to fender.
Maybe I could find a Blazer body for cheap, as the width is much wider than the Clod body. :?:
Post by andymac0035 » Wed Nov 02, 2016 6:10 am
The Bronco body for the Acender drops right on that tub! I test fitted one to a stock clod once and the wheel base looked spot-on.
Looking at your layout, I'm surprised you didn't reverse the transmission to put the drive shafts on the same side that the old steering linkage was on.
Post by SFC K » Wed Nov 02, 2016 10:33 am
andymac0035 wrote:The Bronco body for the Acender drops right on that tub! I test fitted one to a stock clod once and the wheel base looked spot-on.
The old Steering linkage cut outs were not wide enough for the centered output for the axles. Also, I wanted the motor to face forward and it needs the clearance to fit. I still have to cut away a bit more to get a brushless set-up to fit. I'm still not completely sold on this Transmission yet either. It may be swapped for a SCX-10 trans...
Post by KONG » Wed Nov 02, 2016 4:08 pm
Post by GRAVETXT-1 » Mon Nov 14, 2016 8:58 am
Its funny I considered doing something like this a while back but then thought it a bit crazy... go Jeff! 8) :thumbsup:
Post by SFC K » Mon Nov 14, 2016 1:12 pm
I got a ton of work done over the weekend. I will update this tonight with some pictures. :)
Post by SFC K » Tue Nov 15, 2016 2:06 am
Its a roller. Working on mating a SCX-10 Transmission now and for the first fitment test with a brushless system, its going to work perfect! I just need to mount the plate to the bottom of the stock Clod chassis now and get slightly longer drive shafts. I shortened one of mine a while ago when using DIG on my old Comp crawler.
For the links, I ended up keeping the links in line and installed custom pan hard bars to keep the axles centered underneath. Using a center mounted transmission does not allow much room for a traditional triangulated 4 link set-up. Shocks are Traxxas big bores, with some spare silver springs I had laying around. The stock red ones were to stiff and the front is shorter in length.
Next, I pulled out a body I had laying around. :mrgreen: Looks good, don't it? :mrgreen:
Post by andymac0035 » Tue Nov 15, 2016 5:09 am
=D> :thumbsup: =D>
I am liking how this is turning out! :popcorn:
Post by Sixtys Guy » Tue Nov 15, 2016 8:55 am
Tough looking truck!
Post by GRAVETXT-1 » Tue Nov 15, 2016 1:43 pm
Impressive! 8)
mrgrimm
Post by mrgrimm » Thu Nov 24, 2016 3:20 pm
THis is cool, mix and match and using the spine from the original bad Halgars trucks are cooler than mine monster truck itself! Should be a good working and looking combination in the end.
Monster trucks rule :)
Post by SFC K » Thu Nov 24, 2016 7:00 pm
I got some more work done it. Drive shafts are in. I got some spares from a friend for an SCX-10. Had to modify one a little as it was too long. Body is now painted and detailed.
I still need to get a TX/RX and servo for it to be a runner and mount the body. I am still looking for Tire and rim combo for it. I think I will settle for GMade black 2.2 beadlock rims, and RC4WD Tractor tires for it.
Post by SFC K » Sat Nov 26, 2016 9:58 pm
I forgot to mention earlier, when using the SCX-10 transmission, a AX-10 crawler skid plate fits perfectly in-between the stock chassis for mounting the transmission.
