Alex's ZRP Retro Racer aka ???
- GRAVETXT-1
- Regular Member
Re: Alex's ZRP Retro Racer aka ???
Unique build one of a kind! Next update will be with body mounted I have chosen a Clod hard body not very original but limited choice in this area. More photos see previous page for first lot
- Attachments
- retro build roller 009 (Small).JPG (52.96 KiB) Viewed 933 times
- retro build roller 010 (Small).JPG (53.19 KiB) Viewed 933 times
- retro build roller 011 (Small).JPG (54.77 KiB) Viewed 933 times
- retro build roller 012 (Small).JPG (54.05 KiB) Viewed 933 times
- retro build roller 013 (Small).JPG (52.96 KiB) Viewed 933 times
- mojave 001 (Small).JPG (73.65 KiB) Viewed 933 times
- Approved Member
Wow Alex, man don't know how missed this build! So the body you mentioned to me earlier is for this chassis? Love the old skool look of this build very clean congrats.
- GRAVETXT-1
- Regular Member
Thanks Marty yes the Clod body I mentioned will be mounted on this truck I was going to use a Mojave II hard body but turned out to be one inch too long so got a refund on it.
Sadly ZRP Retro Racer was not set up for Clod body ( unlike CPE Time Warp which is
) granted I would have to extend mounting brackets inwards/ outwards but that is easy.
So have had to reposition mounting holes 0.7 of an inch will fire up drill press tomorrow. Wish me luck drilling mounting holes in hard body's has to be the least enjoyable thing in this hobby. Ugh!
- Attachments
- ugh! 001 (Small).JPG (43.43 KiB) Viewed 908 times
- Approved Member
I see what you were saying with the other holes being that close. You could get a sheet of .040 styrene and cover whole underside of the bottom of the bed. It will strengthen those spots close with the holes. It will make it heavier but it will look very neat once done and cover up all those other hole you don't need. I was going to do this to my building as well before the body got trashed.
- GRAVETXT-1
- Regular Member
Managed to drill body holes spot on and get body exactly where I want it not easy. Body sits nice and low true retro style
Got these scale shock boots off RC4WD they are bloody massive! Way to wide to fit knock off shocks that I have surely RC4WD scale shocks aren't that wide? My bad should have checked measurements they don't look right just too big shame as they would look sick with body design I have in mind;
# Body sprayed black
# Neon green CLAWING DEAD text on each door
# Grill sprayed neon green
# Custom aluminum roll bar (stock roll bar will not fit due to body mount holes!)
Not having any luck finding a decal maker that can make me a custom set of decals for the doors each one I contact say it is not possible blah blah blah so I will have the Clawing Dead text PRO airbrushed.
Wont be cheap but be worth it.
- Attachments
- body mounted 001 (Small).JPG (77.25 KiB) Viewed 882 times
- body mounted 002 (Small).JPG (77.97 KiB) Viewed 882 times
- body mounted 003 (Small).JPG (60.71 KiB) Viewed 882 times
- body mounted 004 (Small).JPG (94.16 KiB) Viewed 882 times
- body mounted 005 (Small).JPG (98.27 KiB) Viewed 882 times
- body mounted 006 (Small).JPG (45.05 KiB) Viewed 882 times
- body mounted 007 (Small).JPG (51.12 KiB) Viewed 882 times
- body mounted 008 (Small).JPG (48.23 KiB) Viewed 882 times
- body mounted 009 (Small).JPG (46.8 KiB) Viewed 882 times
- body mounted 010 (Small).JPG (50.07 KiB) Viewed 882 times
- Approved Member
Alex,
Dude that looks bada$$ bro! Man you done great on the new body holes turned out perfecto.
This is the exact stance and ride height i'm going with my old build now. Looks just like a truck out of the TNT Renegade monster truck series out of the late 80's congrats man.
- Sixtys Guy
- Approved Member
Looks great Alex. The Clod body looks great!
- GRAVETXT-1
- Regular Member
Thanks Marty & Mark appreciate the comments
glad I didn't go for RC4WD Chevy body overly expensive and complex not to mention slightly longer than Tamiya Clod body I believe.
Old school Tamiya FTW
- GRAVETXT-1
- Regular Member
Our very own Aron aka SicNme products made me this amazing one off custom battery tray for this retro build. Beautifully simple design which attaches to the chassis plates by two nuts and bolts per side. Battery tray simply sits on top of the two chassis x braces.
As you can see the tray fits neatly around body post mounts and gives enough clearance for the body to sit on top. Sliding lid is simply held in place by one screw per side.
Aron is the man
Aron is the man
- Attachments
- battery tray mounted 001 (Small).JPG (37.9 KiB) Viewed 761 times
- battery tray mounted 002 (Small).JPG (38.32 KiB) Viewed 761 times
- battery tray mounted 003 (Small).JPG (33.53 KiB) Viewed 761 times
- battery tray mounted 004 (Small).JPG (36.79 KiB) Viewed 761 times
- battery tray mounted 005 (Small).JPG (35.37 KiB) Viewed 761 times
- battery tray mounted 006 (Small).JPG (56.9 KiB) Viewed 761 times
- GRAVETXT-1
- Regular Member
Few more photos
- Attachments
- battery tray mounted 007 (Small).JPG (53.24 KiB) Viewed 761 times
- battery tray mounted 008 (Small).JPG (44.62 KiB) Viewed 761 times
- battery tray mounted 009 (Small).JPG (46.63 KiB) Viewed 761 times
- battery tray mounted 010 (Small).JPG (53.66 KiB) Viewed 761 times
- battery tray mounted 011 (Small).JPG (50.03 KiB) Viewed 761 times
- battery tray mounted 012 (Small).JPG (48.47 KiB) Viewed 761 times
Awe man, that battery box sucks. What a hack. Glad it came out sort of ok for ya bud.
- Approved Member
awesome build just not sure that the bolts sticking out of the bottom of the axle mounts is a good idea.. Look like they will catch on things.
- GRAVETXT-1
- Regular Member
- GRAVETXT-1
- Regular Member
Thanks buddyratpower396 wrote: ↑Thu Mar 30, 2017 2:03 amawesome build just not sure that the bolts sticking out of the bottom of the axle mounts is a good idea.. Look like they will catch on things.
- Sixtys Guy
- Approved Member
Battery holder looks awesome!
Users browsing this forum: Google [Bot] and 2 guests
