Anyways it all started with a rather crude drawing after seeing a few mrc around the Web with mt tires. Think im2tall was the first to get his actually together more than others
So here was the concept drawing that started my journey
Yup you read that one note right this thing was to be designed around a 1/16 Traxxas vxl trans and a massive 540 motor!! I figured monster trucks have insane amount of power so why in Sam hill can't a 1/18 mt be the same!
That lead me to work on axles and already made c-hubs for the mrc to make it a little stronger and a little better. Axles that let me flip the ring and pinion to negate some torque twist. C-hubs with king pin inclination to help steer those tlt-1 tires/wheels.
I'll try to keep this from getting to long winded no promises though!
So here is a early render of the truck in tinker cad (I'm to cheap for a better cad program)..
The chassis by the way came out really good for a first run its taken so much time to get this little guy into the physical world
A picture of the first parts on a mrc scaler to see how they help up well they passed!... Mostly later on I'd find out the axle couldn't survive landing from jumps!
But to continue on this story I was able to finally get the chassis printed! (probably forgot to mention I use shapeways to bring my designs to the material related!)
It is same width at the trans mount as the mrc and uses the same bolt pattern
Fast forward a couple weeks and taking my mrc scaler apart for a donor and we get this!!
Wait a minute that's not a vxl trans!?
Remember how I said it has the same bolt pattern and width of the mrc chassis? This truck is setup to be a drag and drop conversion for your mini crawler!!!
So I broke down and put some mounting holes in my mini lst body dag gummit I think Im onto something!
So after breaking the custom axle I ended up designing a new one hopefully it's stronger!
This has mostly stock mrc link shock mount geometry so once again drag and drop if ya get my theme with this truck.
And now the axle as of a few days ago
And that's all so far I could go into more detail bit I'll let yall ask me some questions and any feedback.
I do plan on having this chassis and axle available for folks down the line on shapeways!
Sorry about the long opening post and lots of photos!!
